Engine Strip Down And Rebuild With Lots Of Confusion :d
#31
Posted 27 December 2011 - 05:38 PM
Andy just twigged its the two each side of the block. What's the two at front of engine where it joins to transmission?
And what about the three in the head?
Do you just drill them then lever out?
#32
Posted 27 December 2011 - 05:40 PM
Now the hard part what colour mmmm
#33
Posted 27 December 2011 - 05:41 PM
#34
Posted 27 December 2011 - 07:26 PM
Its Probably not oil plugs but look similar three in a line on underside of head above the valve chambers if that makes sense
#35
Posted 27 December 2011 - 08:02 PM
#36
Posted 28 December 2011 - 03:54 PM
Your chambers are so shiny got some cleaning to do.
#37
Posted 28 December 2011 - 09:42 PM
Ultralight flywheel, new radiator as well as looking into improving ignition and electrics all on top of standard replacements. Just looked at how easy it is to install a remote fire system tempting
I'm skint to begin with but it will be worth it in the end.
Just a quick query last year I did work to head when changing head gasket and cleaned oil breather out with paraffin this time it's chocker block with mayonnaise looks crap so might get a shiny new one any idea on what would of caused this?
#38
Posted 29 December 2011 - 05:43 PM
for a 1993 1275cc mini it is a verto clutch with engaged starter? So if i was after a nice shiny lightweight flywheel is this the correct one http://minispares.co...pid=37371=
Replacing the clutch pad apologies if thats not what it is called cant seem to find it just whole clutch kits??
Will this http://minispares.co...pid=37139= and a head gasket set cover everything i need for the rebuild?
also got confused last time i got the bk450 head gasket but is the copper af460 performance gasket better??
Cheers just trying to balance my paycheck out.
#39
Posted 29 December 2011 - 05:53 PM
can anyone recommend other supplies than mini spares used some for bits and bobs but dont want to be mucked about with crap parts
thank you
#40
Posted 29 December 2011 - 06:10 PM
#41
Posted 29 December 2011 - 06:29 PM
#42
Posted 29 December 2011 - 06:33 PM
#43
Posted 29 December 2011 - 06:45 PM
think i might find a machine shop and get everything checked over, get them to check what rings and bearings i need maybe even to run the milling machine over and replace the cam bearings.
#44
Posted 29 December 2011 - 07:04 PM
#45
Posted 29 December 2011 - 07:28 PM
How much do they tend to charge for this work just approx
