'95 Spi Cooper
#31
Posted 09 April 2012 - 01:30 PM
I shall be stripping my old engine very soon, as soon as I have this one running, the engine can take centre stage!
#32
Posted 09 April 2012 - 05:27 PM
Dam studs!
welding
measuring up the rear valence
Another layer of paint on the doorstep!!
Hopefully when this is all welded in, I can get the suspension and temp engine in and start on my actual engine, the reason for this re-build
Edited by RayBoogs, 09 April 2012 - 05:29 PM.
#33
Posted 09 April 2012 - 06:08 PM
#34
Posted 09 April 2012 - 07:30 PM
Haha, well mine hid this lot quite well! And my doors are still shot! but they're in the shed,out of sight out of mind!
#35
Posted 09 April 2012 - 09:46 PM
#36
Posted 09 April 2012 - 09:50 PM
Re-skinning looks hard, and new doors are too expensive!!
#37
Posted 10 April 2012 - 12:37 AM
#38
Posted 10 April 2012 - 05:17 PM
#39
Posted 10 April 2012 - 06:24 PM
http://www.theminifo...n-competiton-2/
Edited by cliche, 10 April 2012 - 06:26 PM.
#40
Posted 10 April 2012 - 06:58 PM
#41
Posted 13 April 2012 - 05:15 PM
But, as per usual, 2 bolts and threads in the subframe have stripped so yeah, will be drilling out and tapping a new thread.. yay!
2 steps forward, 1 step back haha!!
Now, wheres my Zeus book.....
Edited by RayBoogs, 13 April 2012 - 05:16 PM.
#42
Posted 29 April 2012 - 06:32 PM
I'm getting very close now, going to be booking the mot for 2 weeks time, so thats my deadline to have it running so I can iron out and issues before L2B.
Right now for the pictures
Passenger side radius arms, all complete, torqued up, etc etc.
drivers side, still needs a thrust washer and grease cap to be fully complete (on order).
Cut off the old crappy valance support brackets
welded on one new on so far
I'm all prepped for the second one to go on, and I've drilled all the holes for the rear valance to be plug welded on.
As soon as my bits get here (thrust washer, grease cap, wheel nuts and a grub screw for the drum) the rear wheels can go on and it will be off the axel stands at the rear. The engine should, hopefully if everything goes to plan be going in this weekend. Then its just plumbing it all back in and putting on the front hubs and then hopefully, I can drive it
I've also been thinking more and more about this fast road engine I'm going to be building, and I think, I'm going to go carb'd, I like the injection system but if I'm going to tune it I want to go all out and I just don't have the money at the moment, so I think a nicely tuned carb engine, maybe a 266 or 276, weber 40 or more than likely a HIF44 or twin 1.25/1.5 su's and with a 1330 bore, but this could and probably will all change.
#43
Posted 30 April 2012 - 07:06 PM
Tonight I have finished the welding!!!!!! YAY!! Pictures will follow soon. Also the handbrake cables are on not as exciting but still.
I should be borrowing a mates engine crane for this weekend, if not a family friend runs a tool hire business so I ca get one from him if not, all things going well the engine should be in this weekend and I can start plumbing it in.
#44
Posted 03 May 2012 - 10:15 AM
#45
Posted 03 May 2012 - 05:41 PM
Got another update aswell, the rear suspension is fully complete both sides. Although I have slight play in the drivers side bearing even though its torqued right up, may have to remove it all and see if I can get to the bottom of it.
Anyway, engine in this weekend, I've got my hands on a chain and pully, but if this doesn't work I'll be renting a crane.
Thanks for looking
