yeah did that, and it just bent the filter, there only thin, plus how are you supposed to turn it the whole way round, there's no room!
You have to use a big, wide but sharp ended screwdriver, hammered all the way through and out the other side of the filter. (a thin narrow screwdriver will penetrate the filter more easily, but will then just tear through the metal casing when you pull on it). The casing will initially just bend and deform at first, but you just have to perceiver until you've made a hole, then keep at it until you have driven it through and out the other side.
With the front grille removed, if you hammer the screwdriver in through the gap in the front panel, from the rad side of the engine bay, (as close to parallel with the engine block as possible), then that should give you enough room to move the filter by about a 1/4 of a turn. That should loosen it enough to then be able to remove the screwdriver and then undo it the rest of the way by hand. If not, then you just pull the screwdriver out again and whack it in a second time at about 90 degrees to the first holes you made and then give it another 1/4 of a turn.
It's messy and bit primitive, but I've never had a problem doing it this way. I even have a special old screwdriver that I keep exclusively for doing it with. I've tried using various specialist filter removal tools over the years, but I find that there's just not enough room to use any of them properly in a mini engine bay, so I still prefer the brutal screwdriver and mallet routine.
