I think it's time for another quick update!
so I have run into a slight problem,
there is a weird chattering/grating noise coming from the front passenger side of the car,
I've deduced (with help from passengers) that it is further towards the edge of the car than the engine.
But it only happens over about 50mph
I first thought that it was the wheel bearing that was causing the noise,
so I have replaced it,
this is what it looked like before:
I'm not sure whether that is mullered or not, but hey, gives me peace of mind
however.
It hasn't stopped the noise.
next step is to try putting the arch back on that corner to see if it is the body panels rattling...
other than that the only other thing I could think of is that there is something stuck in the cv gaiter which is pinging around in there...
but hey, I'm sure that it will be sorted
hopefully before MITP...
when I replaced the wheel bearing,
I decided to fit my new brake kit, which is allowing me to go down to 10'' wheels
which I'm picking up at MITP which means that the car needs to be done by then
but anyway, time for pic of fresh brakes:
They look so small behind 12's!
I think my Mini is getting used to being in this position...:
There were several issues:
1. The drive flanges didn't fit to begin with, so we had to remove the studs from the disks, then fit the flanges and then pull the studs back through
2. The disks wouldn't fit over the hubs, which turned out to be because the hubs were so covered in crud and the internal diameter of the 7.5'' disks are smaller than the 8.4''s by about 5mm...
3. The callipers needed some material taken off so that they would actually fit on to the hubs over the disks...
Well it is still a cool looking car lol
i would wait untill u get the 10's, not much point in putting u disks on older rims giving the fact thayt ur going 2 change them anyway
meh, it's covered in rust
and apparently it is safe to put the smaller brakes on
I think that's all for now...
Edited by rob963, 21 July 2012 - 08:54 AM.
