Calling All Suck Thru Sc's
Posted 12 July 2012 - 08:33 PM
Question is, whilst changing the rings i may as well bore out, currenly 1293cc, what shall i go for without getting too hot?
Oh and out of interest, good old Smart Performance put new rings in less that 400 miles earlier ( no shock there!)
Cheers in advance
Posted 12 July 2012 - 09:06 PM
Posted 12 July 2012 - 09:30 PM
Posted 13 July 2012 - 07:46 AM
Well I've only had the head off, the bores looked ok. But its more of a case of whilst I've got the engine out, put some decent pistons in, which begs the question what size bore to get max power with min heat issues.Have you actually stripped the engine ? You'll be lucky if just a ring is damaged, it will have most likely cracked the ring lands on the piston.
FYI it's main purpose in life is to be a weekend, sprint/ hill climber , not for every day use. I'd like to get 130+ bhp. Got to 120bhp as a 1293cc with fueling issues.
Posted 13 July 2012 - 09:54 AM
No. 4, failing would definately suggest to much heat and running into det. Your engine may benefit from dry decking and a bypass hose on the flywheel end of the engine.
In my experience of failed ring lands, little damage is done to the bore. A new set of pistons and a hone should be all that is needed. You could maybe consider a piston with a bigger dish.
Posted 13 July 2012 - 12:08 PM
Change the orientation of your supercharger.
Posted 13 July 2012 - 02:44 PM
To What?
Posted 13 July 2012 - 02:54 PM
I think the comment that Smart performance are responsible for a ring failure should be removed. You have no evidence of this. My guess is that you have detonation which has caused the head gasket failure and piston failure. As Phil says, more likey ring lands than rings. So the reality is that either your installation is flawed and either making too much heat or the CR is too high. Or possibly the RR guy ran it lean or with too much advance.
Cr is 8.3. Who said smart performance were to blame. Just stating the fact of who installed it and when. I'm entitled to a 'no shock there' considering the problems he caused me in the past. The RR guy - stuart at vmax ran it at about 27 degrees at 4500rpm and I think it was running rich at the time.
But anyway, back to the question, what cc gets best balance?
Posted 13 July 2012 - 07:54 PM
27 degrees advance is quite a lot for a charged engine, I never run more than 25 on boost. What boost were you making at 4500rpm?
Posted 13 July 2012 - 08:56 PM
I agree with Wil about the 'smart performance comment' I read it exactly the same way.
Whether or not you meant it, it sounds like you're suggesting they're at fault.
Posted 14 July 2012 - 07:30 AM
Posted 14 July 2012 - 08:00 AM
I have considered a mega jolt, but it just seems like more work ( lot of scratching around for parts) and I just want to get my car on the road and drive it as soon as.get rid of the dizzy its just point less . ive got a few good 1293 supercharged megajolt maps round
What tipped you over the edge and made you go for the mega jolt? I ask as I would need to get charger set properly first, before going down the mega jolt route otherwise I foresee lots of setting up problems over all not knowing if its the mega jolt or charger set up.
Posted 14 July 2012 - 08:02 AM
I think it is clear that you are infering that the cause of the failed rings is as a result of installation. Be honest with yourself.
that's interesting, I was advised to go to 27. I'll keep it in mind when setting up again. cheers
Posted 15 July 2012 - 08:30 AM
i did a hill climb . now with out a helmet on you can hear it pinking . with one one not so much . i just said screw it and gave it back ..
megajolt was easy .. cost me $50 ( 25 pound ) to get a trigger wheel put on my pulley , and a normal one at the same time .
few bits from trigger wheels .com . like the trigger wheel and some shield wire . and a unit its self
$30 coil pack ( 15 pound ) free crank sensor . make up some brackets for the pack and sensor . and som ht leads
got a map off another forum from a supercharged mini with the same spec as mine
and ran it . no more problems
also stopped the car stalling when you came to a stop sign . as you can play with the advance at idel .
just do it the megajolt ... bit of reasearch and you will have it done in no time
Posted 15 July 2012 - 06:49 PM
Hi there,i was in the same boat as you . wanting a dizzy that worked . got a aldon one that was ment for supercharged motors . it was **** up top and would pink under load . even when retarded alot .
So the trigger wheel fits ok on the s/c pulley without fouling the rad? Excuse my ignorance, is the megajilt something you link up to a laptop to set up.
I've also had it on the RR at aldon and reckoned it was the cam, but i've only got a tame swiftune cam on it. I have a nagging feeling it might be the carb, so I got a spare to compare when up and running.
