snapped a wheel stud.
Posted 14 March 2006 - 12:03 PM
well life was good up until about 20mins ago when i snapped a wheel stud clear off. so now i got 3 full wheel studs and half of one. i was doing the wheel nuts up and then. pop. off it came. not particularly happy now.
so my question today is:
1) how the hell do you remove an old wheel stud.
2) what size will i need (austin 1982 mini HL, all imperial stuff and drum's all round)
3) am i going to need any special tools. as i have little/no money what so ever.
cheers,
going to go cry now. :'(
Posted 14 March 2006 - 12:07 PM
remove wheel and drum
tap stud through backwards with hammer
get a new stud and it will just fit in without you having to take the pads off
push it as far back thru as possible and put on the drum and wheel and tighten it up
should be able to buy a new stud or you can get one from scrap yard
Posted 14 March 2006 - 12:08 PM
like dosen't suck after all!!!
also is this the stud i would need.
http://www.minispare....aspx?pid=35283
Posted 14 March 2006 - 12:10 PM
Posted 14 March 2006 - 12:11 PM
i love the mini forum!
Posted 14 March 2006 - 12:23 PM
Posted 14 March 2006 - 12:30 PM
Posted 14 March 2006 - 01:47 PM
Re-torque it after 24 hours, as the stud may pull through a bit more with a bit of driving and make the wheel nut loose.
dose mean i need a torqe wrench 1st........arse. have to see if i can borrow one next time to stop me snapping anymore studs.
also seeming as i'm ordering a stud. what wheel nut will i need. as half a stud is stuck in the current one.
Posted 14 March 2006 - 01:51 PM
Posted 14 March 2006 - 01:54 PM
apply pleanty of grease to stop them ceasing up
Posted 14 March 2006 - 02:04 PM
Posted 14 March 2006 - 02:05 PM
also those wheel nuts don't look like mine (i use the "if it don't look the same it won't fit" method to mechanics)
here's the snapped one:
http://img.photobuck...g_Adam/nut3.jpg
http://img.photobuck...g_Adam/nut2.jpg
http://img.photobuck...g_Adam/nut1.jpg
Posted 14 March 2006 - 02:09 PM
i don't know if you can buy them
Posted 14 March 2006 - 02:11 PM
i hate not having a job. .
cheers all.
Posted 14 March 2006 - 02:12 PM
11inches arcorss the metal part (hub or whatever) or is that right.
wow 11" wheels
i think they will probly be 12" looking at the nuts used
