snapped a wheel stud.
#16
Posted 14 March 2006 - 02:14 PM
#17
Posted 14 March 2006 - 02:17 PM
#18
Posted 14 March 2006 - 02:18 PM
#19
Posted 14 March 2006 - 02:21 PM
#20
Posted 14 March 2006 - 02:22 PM
#21
Posted 14 March 2006 - 02:27 PM
WERE THE FUDGE IS MY WALLET!
edit.
under the monitor i'm looking at. d'oh
#22
#23
Posted 14 March 2006 - 03:28 PM
Theres some people that will say do not use any grease! Since it could allow the nuts to come loose again and will alter the setting it should be torqued to.
Common wives tale *
grease the shoulder of the nut (not thread of bolt) use copper grease and apply sparingly.
it stops the nut face siezing to the recess on the wheel, the torque against the wheel will not be affected.
classicWhere did you last have it?
#24
Posted 14 March 2006 - 04:02 PM
apply pleanty of grease to stop them ceasing up
As nick said never apply grease / neversieze / copper slip to threaded portions of nuts and bolts they should only be applied to the shouldered portions other wise you will over torque the nut/bolt, Only oil can be applied to the threaded portion and this should be enough to stop it siezing, I've had quite a few wheel nuts sieze on me and they were coated in copper slip!!!
#25
Posted 14 March 2006 - 06:58 PM
Guy.
#26
Posted 14 March 2006 - 09:43 PM
Just a thought if your really skint as if its a read one then there is probably no rush. I know someone who has only 3 studs on a nissan primeria and it has passed countless mot's etc like that and never caused any problems
#27
Posted 14 March 2006 - 10:08 PM
There are 4 of them for a reason
Not only that if you leave it off it could stop the wheel from seating properly with the hub causing you to have a vibration an certain speeds
And the only reason why I can think of that Nissan primeria passing a mot with only 3 studs is
That the wheels were covered by hubcaps and are not removed for the mot
You could only have one stud/nut on all 4 wheels then put hubcaps on and as long as every thing else if fine on the car it will most probably pass a mot
#28
Posted 15 March 2006 - 08:02 AM
#29
Posted 15 March 2006 - 08:18 AM
Im not recomending only using 3, Just saying that I only currently have 3 have driven a few thousand miles like that and its not been a problem.
#30
Posted 15 March 2006 - 11:36 AM
Not is it potentially dangerous, but in the event on an accident, its something an insurance company could use to invalidate your policy, potentially leaving you with massive bills. I don't think its worth the risk of not replacing a stud that costs a few pence!
