Heater!
121 replies to this topic
#61 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,189 posts
  • Name: Neil
Posted 14 March 2013 - 08:40 PM
Remove the stat, place it in a pan o water then heat it up until the stat opens or not a sthe cas maybe.
What year is your car and model.
The old thermostat is kaput, I've just tied it in boiling water. Dad won't let me try the new one
Talk about a hiding to nothing. Take it from me and a few others on here even new ones fail. Been there done that and got the T shirt. Its just something to check off the list.
Your Dad may not like it but honestly it does happen. if it does prove to work then happy days just a new gasket needed.
#62 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 14 March 2013 - 08:43 PM
The water pump had crossed my mind! I didn't think the Thermostat stopped the flow to the heater, only the radiator!
Otherwise the heater would go from cold to hot virtually instantly rather than getting progressively warmer!
If I'm talking rubbish please shoot me down
Nope not talking rubbish thats why i said if anybody knew to correct me.
#63 its_courts28
its_courts28
  • 644 posts
Posted 14 March 2013 - 08:47 PM
So if the thermostat works what do you suggest?
#64 Carlos W
Carlos W
  • 10,115 posts
Posted 14 March 2013 - 08:50 PM
Air lock or water pump
#65 Carlos W
Carlos W
  • 10,115 posts
Posted 14 March 2013 - 08:52 PM
But if the temperature gauge worked you could possibly rule out or diagnose a water pump as if the water pump isn't working properly the engine is likely to run too hot
#66 sonikk4
sonikk4
  • 16,189 posts
  • Name: Neil
Posted 14 March 2013 - 08:53 PM
Just trying to think of an easy way to check the water pump without disturbing the system. It could just be an air lock so where the heater matrix pipework comes out and to the engine disconnect the pipe at the engine and top up with coolant. Keep the pipe as high as possible when topping it up.. Reconnect it and then try again.
#67 Carlos W
Carlos W
  • 10,115 posts
Posted 14 March 2013 - 09:06 PM
It would be really good if you could seal a funnel into the end of the pipe whilst doing this and squeeze the pipe that's still attached to the car and see if any bubbles come out!
I'm going to end up driving to Yorkshire to fix it myself if its not sorted soon!
#68 its_courts28
its_courts28
  • 644 posts
Posted 14 March 2013 - 09:07 PM
So close to giving up
#69 its_courts28
its_courts28
  • 644 posts
Posted 14 March 2013 - 09:09 PM
Where abouts are you? I could come to you if you're not too far away and would help?
#70 Carlos W
Carlos W
  • 10,115 posts
Posted 14 March 2013 - 09:10 PM
Just trying to think of an easy way to check the water pump without disturbing the system. It could just be an air lock so where the heater matrix pipework comes out and to the engine disconnect the pipe at the engine and top upp with coolant. Keep the pipe as high as possible when topping it up.. Reconnect it and then try again.
I'm in Kent! Where abouts are you?
#71 SMP
SMP
  • 346 posts
Posted 14 March 2013 - 09:11 PM
Having read through this post i have seen a few references to "push for hot". On mine you definitely pull the knob on the switch panel to get hot!
Steve
#72 Carlos W
Carlos W
  • 10,115 posts
Posted 14 March 2013 - 09:16 PM
Steve
If this is the issue I'll buy you a pint
#73 its_courts28
its_courts28
  • 644 posts
Posted 14 March 2013 - 09:18 PM
A long way away!
#74 its_courts28
its_courts28
  • 644 posts
Steve
It isn't, I've tried both pushed in and pulled out
#75 Carlos W
Carlos W
  • 10,115 posts
Posted 14 March 2013 - 09:19 PM
Are you pushing or pulling for hot?
And whereabouts in Yorkshire are you?
