Attempted Theft In Broad Daylight
99 replies to this topic
#76 wile e coyote
wile e coyote
  • 1,230 posts
Posted 12 June 2013 - 01:18 PM
Glad they didn't get your car! Although probably frowned upon by the authorities, it's always appealed to me to place a large vertical spike under the driver's seat....relies on having a good memory though!
Many moons ago an old fashioned surreptitioouly hidden kill switch spliced into the LT circuit saved my car from a similar scrote - costs pennies, it not exactly foolproof but would at least slow the sods down for a while....
For the sake of a fiver or so the, I think its called , discarnect (or something like that) is a sound investment too...
#77 pierres
pierres
  • 586 posts
  • Local Club: No
Posted 12 June 2013 - 01:35 PM
Could you tell me how you fitted this What wires you broke into and where as i want to do this
regards
#78 DEXISWOLF
DEXISWOLF
  • 545 posts
  • Local Club: Steel City Classics
Posted 12 June 2013 - 01:38 PM
how about a removable gear stick and steering wheel
#79 Daviewonder
Daviewonder
    Needs an extra inch!!
  • 1,020 posts
Posted 12 June 2013 - 01:45 PM
just to let people know i was interviewed by crimewatch which will be aired at the start of July due to the numbers that have gone missing.
70 since last summer nationally with 37 since the new year around the west midlands.
i'll look like a dingbat when its aired but i dont mind.
I challenge you to slip the word 'merkin' into conversation when you're on air.
#80 olds_kool_lews
olds_kool_lews
  • 3,602 posts
Posted 12 June 2013 - 02:49 PM
Why not wire the horn into the interior lighting circuit, with a hidden switch in the boot to make the circuit live, if someone opens the door without the switch being turned off, the horn will sound continuously?
Edited by olds_kool_lews, 12 June 2013 - 02:49 PM.
#81 Daviewonder
Daviewonder
  • 1,020 posts
Posted 12 June 2013 - 03:26 PM
...until they get in and shut the door.
#82 cagy
cagy
  • 892 posts
Posted 12 June 2013 - 03:45 PM
Very sorry to hear about the mini, and by the sounds of it you were quite lucky.
Makes me wonder about bringing my mini back home from France now... In some places you can leave the car unlocked with the keys in it and no one pays attention...
If I do bring it back it's staying in the garage until I get a mega kick ass alarm system and anti-theft devices installed.
Back to you mate, improve security and keep the mini, don't let them win.
#83 scaffers
scaffers
  • 476 posts
Posted 12 June 2013 - 04:36 PM
So
how difficult is a cat 1 alarm to install, for a novice
#84 mab01uk
mab01uk
  • 12,571 posts
Posted 12 June 2013 - 05:59 PM
I used to fit a key locking hydraulic brake valve which were available from Autosafe in the 1970's or today you could perhaps hide one of these brake lock valves somewhere on the car and even remove the lever when parked.
http://www.ebay.co.u...=item2320dd201c
The Disklok is a good start for mechanical security in Autoexpress tests:
http://www.ovat.be/A...AutoExpress.pdf
When my classic Mini's were used as daily drivers I always fitted Yale M69 Car/ Van Security Deadlocks to both doors (half way down) and the boot, (as did companies like Wood & Pickett to their expensive Mini conversions). They were easier to fit to sliding window doors but could also be fitted into later winding window doors if you were careful to avoid interfering too much with the glass drop area/channels.
Originally designed by Yale, the ‘M69’ is well-known within the security industry, where it is used to provide additional protection for motor vehicle doors. There are five lengths of lock cylinder to suit different door thicknesses, fitting into LH and RH standard cases. This lock was once fitted as original equipment to Rolls Royces.
  • Operating bolt throws into striker in door post, and is held positively by action of lock cylinder.
  • Key is turned through 360° to throw and withdraw deadbolt. Keys can be withdrawn in either mode. Bolt withdraws fully flush into case.
  • With components separated, case is sunk into door-edge, mortice fashion. Cylinder is inserted through aperture cut in door panel and is engaged into top face of case. It is then screwed fully into position using two holes in lock face. Finally, set-screw on flange is tightened, and pegs may be driven into face to seal fixing holes. Striker is fitted to door-post, and a trimescutcheon is provided.
  • Brass pin-tumbler lock with up to 1000 combinations. Unshuttered. Brass keys, nickel plated in ‘SX’ series
  • Chromium-plated throughout.
  • Lock and cylinder are brass, case is zinc diecast with steel cover plate and brass extruded bolt. Steel striker and escutcheon.
  • Standard key cylinder
  • Available as pairs/sets
  • http://www.locks4van..._locks_m69.html
Edited by mab01uk, 12 June 2013 - 06:17 PM.
#85 cagy
cagy
  • 892 posts
Posted 12 June 2013 - 06:06 PM
Ouch that is a nasty bit of kit
#86 1984mini25
1984mini25
  • 8,786 posts
Posted 12 June 2013 - 08:41 PM
And very effective as I've found out a few times. normally with jumping in the car, turning the key so the radio lights works etc, turn the key to start and pop goes the fuse (to keep the radio alarm codes) and then the sinking feeling that you forgot to reconnect it.
#87 ToM 2012
ToM 2012
  • 4,066 posts
Posted 12 June 2013 - 08:49 PM
thats a good idea i want to do this but is there away of me getting in the mini on the morning without it going of? also when the door shuts it will go of?
#88 imvarma
imvarma
  • 153 posts
  • Local Club: Tatsu
Posted 12 June 2013 - 08:51 PM
Shocking that this can happen at daytime in a retail park.
I had a switch under the dash in my last mini that cut power to the electric fuel pump I had hidden in the boot.
#89 ToM 2012
ToM 2012
  • 4,066 posts
Posted 12 June 2013 - 08:55 PM
sorry to hear about this to what w*****s why are they robbing minis? are they that easy to rob everytime i go to bed at night i have to look out the window to see if its still there lol
#90 imvarma
imvarma
  • 153 posts
  • Local Club: Tatsu
Posted 12 June 2013 - 08:58 PM
Yes they are that easy to steal! do whatever you can to deter them...
