7 replies to this topic
Posted 09 June 2013 - 10:04 AM
Hi we have a mini mpi 13 1998. Something is draining the battery. We have had it checked, fitted a new alternator, cleaned the brushes on starter motor. Still got to jump start car every day. We think may be alarm, anyone know how to disconnect thanks all suggestions welcome
Posted 09 June 2013 - 11:24 AM
The alarm is located down the bottom right in the engine bay, get the workshop guides on here and they will help you did it
Posted 09 June 2013 - 11:26 AM
I doubt it is the immobiliser, u haven't left your lights on or something have you? Or maybe the charging wire from starter to the alternator is at fault, not the alternator itself? Have you checked your new alternator? Just because its new doesn't meant its working.
Posted 09 June 2013 - 06:08 PM
Have you access to a amp meter clamp type or older inline one? put it on the + cable and see what current drain you have and then track down by removing the connections one by one
Posted 09 June 2013 - 07:10 PM
Am I right in saying that if the bulb in the dash for alternator cct is blown then the charging circuit is dis and therefore not charging? If so, might be worth checking.
Posted 09 June 2013 - 07:15 PM
If the Ign warning light is defective then the alternator wont be charging correctly............ correct
Posted 09 June 2013 - 07:19 PM
Thank you everyone will try these points? I'll let you know how I get on
Posted 09 June 2013 - 08:45 PM
check all earths......and esp engine to baulk head......
Mini Technical Sections →
Problems, Questions and Technical →
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
