What Are These Wires? (Not Tacho)
electrical
7 replies to this topic
#1 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 16 June 2013 - 02:24 PM
After sorting out a lot of bodged wiring on my 1983 Austin mini city, I am now on the home stretch  :-)
I found these wires behind my dials and having looked at some wiring diagrams I'm still not too sure what they are for.
I have two thick green wires going into one female spade terminal.
There is also a Light Green wire with either purple or brown tracer. (Possible even pink if you use your imagination :lol:
On a related note, could someone advise me which page in the haynes manual most accurately matches the wiring on an 83' city E?
Edited by Stiggytoo, 16 June 2013 - 02:25 PM.
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 16 June 2013 - 03:04 PM
Yours falls in the same wiring diagram as my 1980 and I use wiring diagram no 11 which is 76-on UK cars which covers upto the next change of 1984.
The Greens are usually switched 12v feeds and I suspect the other wire is a LG/N-  Light Green with brown tracer wich points towards the flasher circuit on the flasher unit. do you have a flasher unit wired up ?
#3 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 16 June 2013 - 05:03 PM
Well everything seems to work atm apart from the park switch but I don't think they're related. It looks as though the loom could have been changed at one point? Is it possible that these wires are for ancillaries such as clocks or cigarette lighters?
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 16 June 2013 - 06:24 PM
The solid green is a switched 12v supply, some had the flasher unit inside the car, where abouts is your flasher unit mines outside on my 1980 car on the firewall
#5 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 16 June 2013 - 09:37 PM
Yeah, the hazard flasher is on the bulkhead in the engine bay, the indicator one dangles majestically by the steering column.
Edited by Stiggytoo, 16 June 2013 - 09:37 PM.
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 17 June 2013 - 08:07 AM
  What's connected to your indicator flasher then?  The cables you have found very much sound like they are the indicator flasher connection.
#7 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 17 June 2013 - 10:46 AM
My indicator flasher is wired in and working, but as I said, the loom could have been butchered and messed with in the past.
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 17 June 2013 - 02:49 PM
What wiring colours are on the flasher unit ?
