Okay so about a week ago I was told that when braking my front side lights would come on, so I check and confirmed this. also my dipped beam weren't working.
When I looked under the bonnet I found a loose wire and a bullet connecter with a wire wrapped around it, So I connected the wire back up here to see if it would fix the problem and it did.
Now the problem is that my dipped beam still are not working and when I use full beam the off side works fine but the nearside dulls out and the side light and the full beam struggle to light up.
1978 1000.
Thanks guys!
