Dim Dip
electrical
10 replies to this topic
#1 Classic1275cc
Classic1275cc
  • 417 posts
  • Local Club: south lincs mini club
Posted 12 September 2013 - 07:01 PM
1994 monte carlo
is there a fuse i can take out to get rid of dim dip or do i have to snip a wire ? i dont realy wont to snip a wire :(
#2 cal844
cal844
  • 9,659 posts
  • Local Club: TFMOC
Posted 12 September 2013 - 07:24 PM
it is legally required!!
#3 Classic1275cc
Classic1275cc
  • 417 posts
Posted 12 September 2013 - 07:26 PM
reallllllyyyyyyyyyyyy ? how come i see some cars driveing around with little lights on? not day light running lights becasue the cars a to old, they just have basic side lights on because the light is so small ?
Edited by Classic1275cc, 12 September 2013 - 07:26 PM.
#4 Classic1275cc
Classic1275cc
  • 417 posts
Posted 12 September 2013 - 07:30 PM
Hang on just found that they did away with it being law in 1998 due to some eu legislation
#5 Classic1275cc
Classic1275cc
  • 417 posts
Posted 12 September 2013 - 07:35 PM
Yeah its definatly not a legal requirement - http://en.wikipedia....me_running_lamp
(about the 9th paragraph down)
#6 cal844
cal844
  • 9,659 posts
  • Local Club: TFMOC
Posted 12 September 2013 - 07:41 PM
sde lights dim dip CAN be removed, just disconnect it at the headlight end...
#7 tiger99
tiger99
  • 8,584 posts
Posted 12 September 2013 - 07:50 PM
You need to join the blue-brown and blue-red wires or you will have no dipped lights. It is best removed, as if it fails the lights can go out suddenly.
#8 Classic1275cc
Classic1275cc
  • 417 posts
Posted 12 September 2013 - 07:59 PM
the thing with cooling fins on it ? thats kinda looks like its outa a p.c? is that where the b/b and b/r wires are or the red/orange relay ?
#9 Midas Mk1
Midas Mk1
  • 5,789 posts
  • Local Club: S.U.N.M.C
Posted 12 September 2013 - 08:00 PM
Correct, its not needed.
Just disconnect the resistor plug - simple as that, no messing with other wires.
Edited by Midas Mk1, 12 September 2013 - 08:01 PM.
#10 Classic1275cc
Classic1275cc
  • 417 posts
Posted 12 September 2013 - 08:34 PM
rite so thats it! just unplug it ? but if my lights go dead in the future like the otehr guy said that could be a cause ?
#11 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 12 September 2013 - 10:39 PM
  Unplug the resistor or (better plan) remove the resistor fuse and tape the fuse holder up or (best plan) remove the resistor fuse and relay and bypass the circuit in the relay base as said above.  There is a plug-in block that does this which can be found in many Montegos in scrap yards, or you can make a nice heavy duty jumper wire with spades to put in the relay base.
