not sure if auckland auto works (AAA) are still in lake road up between takapuna and devonport but they had a nice disk/drum lathe if you want to take the lip off that way
#16
Posted 15 September 2013 - 08:22 PM
#17
Posted 16 September 2013 - 09:06 AM
Thanks for all the replies guys.
Maybe it is the pistons. They seemed to stick out about 1cm from the rubber seal. Is that normal? I also noticed one had a slight leak.
#18
Posted 16 September 2013 - 09:10 AM
Possibly the pistons have stuck out a bit and need pushing back, Take a look at the pictures of the correct part on Minispares website and compare to how yours look. the very early type do not stick out much but the later ones do as far as i recall.
#19
Posted 16 September 2013 - 09:14 AM
If they are leaking at all replace them
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Rear Opening & Closing Windows For A 1983 MiniStarted by Peter_NottinghamS , 05 Jul 2025 ![]() |
Occasionally Spongy Brakes (96 Spi)Started by TeddytheSpoon , 01 May 2025 ![]() |
Converting To Yellow Tag Brake Master CylinderStarted by Nickj270386 , 29 Apr 2025 ![]() |
Tall Nut Attached Left Front Brake Hose To SubframeStarted by dschwartz1957 , 23 Apr 2025 ![]() |
![]() Handbrake Plate And Sealing PadStarted by dschwartz1957 , 22 Apr 2025 ![]() |
