Mess Of A Engine! Can't Turn Engine Over
102 replies to this topic
#1 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 23 September 2013 - 07:56 PM
ENGINE BUILT BUY TMF MEMBER KAPPA
Hi guys
I can't turn my engine over by hand with the crank pulley, i can however turn the flywheel but this doesn't move the crank pulley. The flywheel nut moves with the flywheel so i don't think its loose.
Any ideas?
Nick
Edited by Nick Warwick, 31 October 2013 - 03:08 PM.
#2 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 23 September 2013 - 08:02 PM
Really doesnt make any sense.
if the flywheel is turning so to should the bottom engine pulley as they are connect via the crank.
if this is the case.
either the woodworth key on the pulley end is broke or missing or the crank has snapped
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 September 2013 - 08:04 PM
If you turn the flywheel and its secured correctly on the crank and the crank pulley stays stationary then you have either a broken crankshaft or the wodruff key in the pulley stripped, you normally wont have enough leverage on the crank pulley to turn it over
My thoughts exactly the same Miglia you type faster though
Edited by KernowCooper, 23 September 2013 - 08:06 PM.
#4 mk1leg
mk1leg
  • 9,343 posts
Posted 23 September 2013 - 08:05 PM
Dito........
#5 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 23 September 2013 - 08:51 PM
Lets just hope the woodruth key is just missing or broken.
Never checked this before how do i go about it? i will go get a quick photo with the crank pulley off just for a better explanation.
#6 minimadles
minimadles
  • 136 posts
  • Local Club: not as yet
Posted 23 September 2013 - 08:53 PM
Put a spanner on the bottom pulley bolt and see if the engine turns over with that
#7 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 23 September 2013 - 09:03 PM
E8A263A1-CFE1-42BA-A5FB-E907B6531161-262
Its in place
Cant turn the engine with a spanner or long bar either
#8 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 23 September 2013 - 09:06 PM
I take it the engine is a none runner, have u heard it running, ???????????????
sound like there is internal damage.
so the fly is defiantly turning????????
will the starter turn the fly???????/
#9 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 September 2013 - 09:09 PM
Is it the photo or is the lower sprocket woodruff slot enlongated clockwise ?
Edited by KernowCooper, 23 September 2013 - 09:10 PM.
#10 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 23 September 2013 - 09:10 PM
No its only just been built so never been run.
Yes i can turn the flywheel with a screwdriver in the starter housing (no starter motor on it just yet)
#11 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 23 September 2013 - 09:14 PM
sounds strange that the fly turns so easy,
take the plugs out and see if the pistons are moving up and down on all 4.
if not the crank has snapped or its on on correctly,
#12 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 23 September 2013 - 09:26 PM
Just looked to see if the pistons move with the fly, they don't so flywheel loose?
If the crank was snapped surely the pulley side would move a little?
#13 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 September 2013 - 09:29 PM
Or the flywheels not locked to the crank correctly ?
#14 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 23 September 2013 - 09:39 PM
I know the engine has had new big end and small end bearings as well as conrods which could explain the not turning over is they have been tightened too much.
#15 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 23 September 2013 - 09:52 PM
If the crank and flywheel are locked up correctly then the pistons and pulley have to turn (unless the cranks broken between no 4 and the rear main bearing) if you rotate the flywheel, is the motor in th car? if not whip the clutch cover off and see whats going on
Edited by KernowCooper, 23 September 2013 - 09:58 PM.
