Engine is out of the car, if i rotate the fly everything in the housing moves freely
Mess Of A Engine! Can't Turn Engine Over
#16
Posted 23 September 2013 - 10:18 PM
#17
Posted 23 September 2013 - 10:49 PM
Is the locator behind the locking bolt engarged into the crank nose and the flywheel boss correctly?
#18
Posted 24 September 2013 - 06:34 AM
Are all the pistons moving up and down
#19
Posted 24 September 2013 - 08:22 AM
#20
Posted 24 September 2013 - 08:46 AM
Not sure on this, never done any work with the flywheel end.
No pistons move.
Forget the flywheel for the moment if the engine won't turn over with a spanner on the front pulley bolt it needs pulling apart it find out what the problem is
I will drop the gearbox off soon to check the crank.
#21
Posted 24 September 2013 - 09:57 AM
Is it the photo or is the lower sprocket woodruff slot enlongated clockwise ?
At last someone spelt it right LOL
Absololutely!
Start again from scratch, or you may regret not doing so later, Probably not much later either!!!!!!!
Edited by Yoda, 24 September 2013 - 10:00 AM.
#22
Posted 24 September 2013 - 10:26 AM
I'd be having the clutch and flywheel off which you need to do anyway to get the box off and see why the flywheels turning but nothing at the other end like the crank pulley, if its all good there then when the box comes off something will be obvious.
#23
Posted 24 September 2013 - 10:56 AM
Didn't really want to be doing all this but like you said better now rather than later ![]()
#24
Posted 24 September 2013 - 04:22 PM
Well turn of events!
I brimmed the engine with oil at the weekend with hope that it was a little dry. Looks like it was very dry.
Plucked up the guts to use a 5ft bar for more leverage on the crank nut and thank god it didn't snap the bolt! movement came back slowly.
Eventually the flywheel started to move with the crank, although i did find that if i move the flywheel it still doesn't move the crank pulley. Would this mean the flywheel keyway is broken?
All 4 pistons move by the way
Thanks for all the help so far guys.
#25
Posted 24 September 2013 - 04:55 PM
Your flywheel isn't connected to the crank properly. You need to remove the flywheel cover and flywheel and investigate whats going on.
The flywheel sits on a taper as well as having a keyway plate like so: http://www.minispare...gs/DAM5923.aspx
Id still be worried if the engine took that much force to turn over. Has it been standing a long time?
Edited by DannyTip, 24 September 2013 - 05:05 PM.
#26
Posted 24 September 2013 - 06:15 PM
It has been stood for maybe 4 months without any oil, thats why i filled it up in the hope it would lube it up.
Just need to get a decent flywheel puller now, whats decent?
#27
Posted 24 September 2013 - 06:55 PM
#28
Posted 24 September 2013 - 07:00 PM
#29
Posted 24 September 2013 - 07:12 PM
I can turn the engine with a large ratchet now, the bar just got it started, slight rust somewhere?
#30
Posted 24 September 2013 - 08:31 PM
Get it checked...
Or if you have to..put some miles on it close to home....with a mobile in yer pocket...
