1983 Metro Daily/possible Track Car
97 replies to this topic
#61 creakyjaws5533
creakyjaws5533
    My jaw needs oiling. Where's the WD40??
  • 1,195 posts
Posted 14 January 2014 - 10:41 PM
Oh okay makes it easier then I'll add that to my list of bits. It's solid green the guy just called it lime green
#62 creakyjaws5533
creakyjaws5533
  • 1,195 posts
Posted 05 February 2014 - 09:46 PM
Hi Guys
A terrible update today
The metro has died ish
I was driving to work on Monday and went to pull away and suddenly there is a horrible grinding in 1st 2nd and 3rd gear not taken it apart yet but its not looking good by the looks its internal gearbox so annoyed only 7 weeks of driving it.
I hope to have a look on Friday depending on the weather really but Ill keep this updated
#63 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 06 February 2014 - 12:10 PM
If it'll drive in 4th then you've stripped the gears off the 1st motion or laygear...
#64 creakyjaws5533
creakyjaws5533
  • 1,195 posts
Posted 06 February 2014 - 12:21 PM
Okay im not sure if I can get it to fourth I dont want to damage it any further is that a hard job?
#65 cradley-heathen
cradley-heathen
    Metro-Man
  • 2,481 posts
  • Local Club: spearmint rhino
Posted 08 February 2014 - 01:00 AM
its not a hard job for a guy like guessworks, but im guessing if your asking how tricky it is, you wont want to undertake the first part of the job, which is getting the whole unit out and splitting the box of it. all you gotta do then is send it to guessworks, and slap it all back together and in again
#66 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 08 February 2014 - 01:52 AM
I want a metro so badly
#67 creakyjaws5533
creakyjaws5533
  • 1,195 posts
Posted 08 February 2014 - 06:48 AM
I taken the engine out of my mini before with the help of some guys from my mini club but the mini is now sat on my drive not working but thats down to the selector being put back wrong. I think people are starting to like metros a bit more especially now there are less of them on the roads
#68 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 08 February 2014 - 06:49 AM
Surprisingly, now I have one, I see plenty more around and there's quite a few cropping up on the flea-bay
If you actually want a metro however, get yourself on to this facebook group....
https://www.facebook...04862436248932/
#69 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 08 February 2014 - 06:50 AM
taking the engine out of a metro is so easy
#70 creakyjaws5533
creakyjaws5533
  • 1,195 posts
Posted 09 February 2014 - 11:03 AM
Alright Guys
Not a proper update but dad is building a new MOT centre in the centre of Bristol and we have been luckily enough that the guy who is having it built is letting me using it to get the car fixed free of charge so hopefully the engine will be out this afternoon/evening and I booking this week off to get the engine split and diagnosed to see what's wrong.
I'll keep you posted
Cheers Jack
#71 creakyjaws5533
creakyjaws5533
  • 1,195 posts
Posted 23 February 2014 - 06:06 PM
A bit of an update,
Got some time to get the hubs and driveshafts off to find the problem but no luck all the spilines loom very good so not them and all the joints are very good condition as well. So took the engine out to have a look inside, whilst doing so I found a snapped engine support bracket which explains the rocking but not the grinding. So took the diff out after the engine was released and that was all in good condition so I'll start on the clutch in the week.
Here's some pictures anyway
#72 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
  • Local Club: Weston Mini Muckers
Posted 23 February 2014 - 06:53 PM
nice work told you i highly doubt it would of been the shafts properly find the plastic like bearings holding the lay shaft have disintegrated
#73 creakyjaws5533
creakyjaws5533
  • 1,195 posts
Posted 01 March 2014 - 08:37 PM
Well this update should put some light on the problem or the lack of one took the clutch housing and everything looked okay the clutch was knackered but not bad enough to be a failure yet small amount of iron filings where the rivets on one side have been rubbing. So I continued to strip down took of the transfer casing expecting to find a problem but nothing all looks as sweet as it can be bearings are smooth so at this point I assumed it must be the gearbox so I continued tbe strip down removed the carb and manifolds and the alternator belt and split the engine and guess what? Its in perfect condition this has to be the strangest feeling ive had, whilst pleased it wasnt broken also kind of annoyed as there is no problem. Any way and a little bit of head scratching and I have this theory one broken rear engine steady two healthy engine steadies, now when the engine is under load the engine moves when there are three steadies its moves very small amount so of one is missing the engine would twist casuing the driveshafts on the cv joints on the diff to move and to rubbing or cause the bearings to jump out of place does this sounds plausible to anyone else?
ill upload some pictures now.
Edited by creakyjaws5533, 01 March 2014 - 08:39 PM.
#74 creakyjaws5533
creakyjaws5533
  • 1,195 posts
Posted 01 March 2014 - 08:50 PM
Pictures
The clutch with the worn rivets
A photo of my MED and K&N lovelyness
Also painted and underbody waxed my subframe
I am loving the huge garage so much space I don't think I want to ever leave it :P
#75 rally515
rally515
  • 3,848 posts
Posted 01 March 2014 - 09:17 PM
Wish i had so much space and under a roof too!! greedy sod :P
