Blue Smoke After Headgasket Change
88 replies to this topic
#76 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 20 July 2014 - 01:48 AM
Easier said Tha done lol! Spent 5k on it in the last 2 years and I need a house deposit hehe
I don't think that there is anything in the book of rules that says you have to get back the money you spent into a car, but good luck.
My mother once said something about throwing good money after bad.
#77 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 20 July 2014 - 01:53 AM
Change 6 stem seals?
Hadeeeeeeee
#78 GenLightening
GenLightening
  • 21 posts
Posted 20 July 2014 - 03:23 AM
you dont need to have any on the exhaust valves, there is no way oil will creep down the valve stem, if the valve stem is not worn it wont go down, if the valve stem is worn the exhaust gasses would push any oil up.
Except when off the throttle, then it'll smoke until you get back on it.
Replace all 8.
#79 jonnyenglish
jonnyenglish
  • 229 posts
Posted 21 July 2014 - 08:06 PM
HI guys ive had a look this evening at changing the valve stem seals but i cannot for the life of me see how to do it without removing the head does anyone have a guide or something? i have bought a tool that is meant to compress the spring so you can do it anyone???? thanks jon
#80 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 21 July 2014 - 08:51 PM
Length of rope in the cylinder and bring engine to TDC, use compressor and bingo.
#81 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 22 July 2014 - 06:03 AM
Personally, i would take the head off, do it properly and lap the valves. Do you have any engineers blue?
#82 Carlos W
Carlos W
  • 10,114 posts
Posted 22 July 2014 - 08:21 AM
I completely agree, the time it takes to remove the head will be saved by the relative ease of changing them on a bench
#83 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 22 July 2014 - 09:52 AM
If you have the valve took which I have and its just the seals you want to change then yes its a job you can do quickly or with the old boys rope trick, buy agree if its in need of valve work then better to whip it off.
#84 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 22 July 2014 - 02:24 PM
You've not put in too much oil have you? Would make it smoke. 4.8L but less if you didn't change the filter.
#85 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 23 July 2014 - 06:18 AM
Off with his head!  Why do half a job twice? Lapping the valves in isn't a huge job and will 'crispen' things up, new valve stem seals and you know your head is sealed up and eliminating those areas from your troubles.
#86 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 23 July 2014 - 07:01 AM
Painful. Sell the bloody thing.
#87 AGRO_RB
AGRO_RB
  • 169 posts
  • Local Club: Otago Mini Owners Club
Posted 23 July 2014 - 07:24 AM
This.
I've spent over $5k in the last 6 months on mine, when I had it for sale recently, I was asking what I'd paid for it, $4500, a huge loss.
You don't build cars to make money on them ;)
#88 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 23 July 2014 - 07:39 AM
Hmmmm yes quite - moreover despite the advice given the OP doesn't really want to follow any of it.
The new purchaser can be made aware of the condition and the price adjusted accordingly.
Done, finished - let the new owner do the work himself rather than the OP attempt to cure it with just half a job.
#89 kansanbrit
kansanbrit
    Starting My Mini Up
  • 1 posts
Posted 24 July 2014 - 04:29 AM
When the head gasket went originally did the engine overheat ? If so maybe the rings are stuck.
