Blue Smoke After Headgasket Change
88 replies to this topic
#46 Carlos W
Carlos W
  • 10,114 posts
Posted 16 July 2014 - 08:03 AM
If you're changing the valve stem oil seals you'll have to take the head off so you'll need another head gasket.
#47 jonnyenglish
jonnyenglish
  • 229 posts
Posted 16 July 2014 - 08:16 AM
It is 20-50! Fingers crossed guys!! The tool I've bought apparently allows you to do the valve seals without having to remove the head so hoping to get away with not replacing the hg!
#48 Carlos W
Carlos W
  • 10,114 posts
Posted 16 July 2014 - 08:20 AM
Be careful you don't lose any collets down the oil ways (or anywhere else)
#49 lsto
lsto
  • 610 posts
Posted 16 July 2014 - 10:08 AM
And make sure the engine is in the right position, don't want to loose a valve in the bore lol
#50 jonnyenglish
jonnyenglish
  • 229 posts
Posted 16 July 2014 - 10:50 AM
Are the valve stem seals hard to do? Should I do them first then change the oil or do the oil and if that doesn't work do the stem seals?? Thanks
#51 Carlos W
Carlos W
  • 10,114 posts
Posted 16 July 2014 - 11:02 AM
I've never done valve stem oil seals with the head in place.
I might give the oil change a go first
#52 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 16 July 2014 - 11:05 AM
Oil change 1st. Its the easiest option.......
#53 jonnyenglish
jonnyenglish
  • 229 posts
Posted 17 July 2014 - 06:28 AM
Well good news guys the oil change was a complete success in the sense that it went well but its still Smokey as you like! Valve seals next! Woop quick question just say the oil had worked and its still blue smoke could that be residue from somewhere or should it have stopped smoking straight away?? Thanks for you help
#54 Carlos W
Carlos W
  • 10,114 posts
Posted 17 July 2014 - 06:34 AM
You'd have to take it for a bit of a run to clear it.
#55 jonnyenglish
jonnyenglish
  • 229 posts
Posted 17 July 2014 - 06:41 AM
What's the chances of it being piston rings? I'm assuming if it is these it's a complete rebuild?
#56 jonnyenglish
jonnyenglish
  • 229 posts
Posted 17 July 2014 - 07:15 AM
One more question ive read everywhere and everyone says "change the valve seals but it wont make a difference" thinking back when we did it we only had 4 that came with the kit if we didn't replace all 8 could that have made a difference? I really need this to work lol I'm getting married in Oct need the wonga but at the same time cant sell it knowing its not mechanically sound its not fair!
#57 Badboytunes
Badboytunes
  • 1,615 posts
A compression test may tell if it is the rings although it depends if it is the oil crontrol ring that has worn. I still think you should take if for a decent run and get the emmisions checked at a garage........
can you post a video of the smoke?
#58 AGRO_RB
AGRO_RB
  • 169 posts
  • Local Club: Otago Mini Owners Club
Posted 17 July 2014 - 07:28 AM
Take it for a good long thrash, and see if it clears. I dont mean a run around the block, I mean a proper, spirited drive on some country roads, load it up, see if it's using any oil or fouling plugs, if it doesnt clear, get a compression test done, don't throw money at things like valve stem seals and rebuilds if you don't have to. A compression, vacuum and cylinder leakdown test will give you some answers to your questions.
#59 jonnyenglish
jonnyenglish
  • 229 posts
Posted 17 July 2014 - 07:36 AM
A guy at work is bringing in his compression tester tomoro so will have a look at that! I will put a video on youtube tho evening of the smoke and let you see what its like its pretty bad to be honest! Does it have to be driven or can it just be revved on the drive (not insured at the minute u see) spose I can drive it round the farm??
#60 AGRO_RB
AGRO_RB
  • 169 posts
Posted 17 July 2014 - 07:51 AM
Nope, it needs to be put under load.
If someone else can drive it, take it out for a good, long run, and give it some stick.
Edited by AGRO_RB, 17 July 2014 - 07:52 AM.
