Posted 25 July 2014 - 08:15 PM
This evening I jacked the car up and rotated the wheel. Again it squeaks but there is no play in the wheel at all in any direction. Just for giggles I tried the other wheel and it too appears to be rubbing. The car is running 12x6 Revo's on standard brakes. Any ideas what this could be and what i should look for?
Thanks for your help.
Posted 25 July 2014 - 08:52 PM
Posted 25 July 2014 - 09:07 PM
Sure it was front and not back? Maybe a brake shoe lining catching or even come adrift. Worth checking around the car as noises have the strangest way of travelling and you think its coming from somewhere when it might not be.
Done afew wheel bearings due to that, people saying its defo the front right and it turns out to be the rear for example.
Posted 25 July 2014 - 11:12 PM
Posted 26 July 2014 - 12:43 PM
Posted 27 July 2014 - 05:27 AM
Okay. So took to it to the garage to have it checked and the pads were bare metal. They changed pads but now there's no pedal pressure - they think master cylinder seal. Thoughts?
Change the disks too.
Yes years ago I repeatedly allowed pads to wear down (no money) and of course they only wear down quicker and quicker as you wreck the surface of the disk. Now I am diligent (read - have the right amount of money to run a car) so pads are always changed ahead of time and I generally change the disks every two pad changes.
In your case, definitely change the disks now as they will be trashed.
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Drum Won't Fit Over Ms2693 Front Brake AssemblyStarted by bemayr , 16 Jun 2026 |
Yellow Tag Brake Master Cylinder QuestionsStarted by John K Series , 12 Mar 2026 |
Time To Bleed The BrakesStarted by Murrayup , 11 Mar 2026 |
Clutch And Fan Noise From Newly Rebuilt 1380 Engine.Started by sam138 , 19 Feb 2026 |
1968 Cooper Parts NeededStarted by Neilmr , 14 Feb 2026 |
