Bonnet is perfect, wing front edges similar but other bits of wings need looking at. Rear arch is the major headache as it's been the scene of one of the worlds worst repairs. Accelerating hard isn't an option, the engine is running so badly it can't be doing 0-60 in less than 30 seconds.Has the leading edge of the bonnet rusted - the wing front edge - rear arch - all areas to keep an eye on
if you have to replace the head lights - they were for another car as well - we used to get them as the ford ones were £xpensive
(can't remember what car thou)
all ways got a slight shudder when accelerating hard (prop)
hope it gives you years of pleasure
After 24 Years, Another Capri
#16
Posted 07 September 2014 - 01:32 PM
#17
Posted 07 September 2014 - 01:37 PM
Change the spray bar !!! Its a cam killer!
#18
Posted 07 September 2014 - 01:50 PM
on the list of jobs, but need to get to the bottom of the rough running first. I think it is just in need of a damn good service and setup so that will happen first.Change the spray bar !!! Its a cam killer!
#19
Posted 07 September 2014 - 02:37 PM
I have always liked the Capri, particularly the first model out (Mark 1?) . They were sold over here not as Ford but as Mercury. They were not particularly popular back then and next to impossible to find these days.
http://www.ebay.com/...=US_Cars_Trucks
#20
Posted 07 September 2014 - 02:44 PM
Wondering if it has the VV carb - if it has get a weber , or at least new chewing gum diaphram
http://www.ebay.co.u...=item4d232c9721
I used to change hundreds over the years - IIRC the black ones are faulty - blue ones better - I think - been a long time ?
as above splash bar (I worked for kent cams in the 80's (1 summer)) we re-profiled thousands
wonder if there is a electronic points conversion for them - must be
http://www.ebay.co.u...=item53eff8d874
also inlet manifold sometimes prone to leaks
also porous float on VV carb - constant rich mix - & the infamous auto choke
Edited by sledgehammer, 07 September 2014 - 03:33 PM.
#21
Posted 07 September 2014 - 02:59 PM
I think beztek ? ignition is popular . At least on beasty pintos.
Bugger im having impure thoughts of screaming pintos and grunty essex's !
#22
Posted 07 September 2014 - 03:15 PM
I always liked the pintos - but a lot of people hated them
setting tappets was awkward , cam cover leaked unless you knew what you were doing
cam belts died at random moments (1.6 valves usually hit , 2.0 miss)
splash bar clogged , vv carb on some was poor , but on the whole a robust engine - in my opinion
anyone else prefer the 4 sp box over the 5sp - in the capri 1.6 2.0 ?
welcome to the Capri forum
(I would have mine back in a heart beat (in the same condition - probably a washing machine now))
still remember putting the hex drive in the head bolts - tapping them to displace the oil & spraying oil everywhere
1986 (D reg) last production year ? - have seen new ones - later registered ones
Edited by sledgehammer, 07 September 2014 - 03:22 PM.
#23
Posted 07 September 2014 - 05:55 PM
Nice one Clive, I have had loads. Had a 1981 2.0GL in bronze but it got scrapped in the end
Looking forward to updates
#24
Posted 07 September 2014 - 05:58 PM
They did do E plate cars , might have just been the 280 specials ....
Funny to see they continued doing them with the xr4i and sold more ..
#25
Posted 07 September 2014 - 06:08 PM
Im pretty sure the Capri was fitted with a twin choke webber, VV carbs being fitted to Mk3 Escorts & Granada's. Could be wrong tho. All mine had webbers.
#26
Posted 07 September 2014 - 07:01 PM
a lot were fitted with VV carbs from new (mk3) -- most were changed to weber later on (1.6 & some 2..0)
usual thing was a manual choke first - then a complete carb change
twin choke weber was/is a lot better
Edited by sledgehammer, 07 September 2014 - 07:02 PM.
#27
Posted 07 September 2014 - 07:08 PM
my first was an 81 2.0 GL in Tibetan gold, reg was KMG282W.Nice one Clive, I have had loads. Had a 1981 2.0GL in bronze but it got scrapped in the end
#28
Posted 08 September 2014 - 02:53 PM
I remember the Pinto......
#29
Posted 08 September 2014 - 03:13 PM
Normally you get cars and they turn out worse than you expected, not better! Life is never simple.
#30
Posted 08 September 2014 - 03:44 PM
personally, i think you should 'mess' with it, or sell now and buy 'nother to mess with.
let's say you do decide to sell though, the next owner might just mess with it ?
