Changes In The Wiring Following Restoration, Questions On Hooking It Up
electrical
3 replies to this topic
#1 Larryville
Larryville
    Starting My Mini Up
  • 2 posts
Posted 12 November 2014 - 03:30 PM
Trying to finish up a 4 year ground up restoration on a MK1  1963 Morris Mini.  (Red in colour) Lots of changes: 1330 engine now instead of 850, disc brakes and all new front end, going from positive ground to negative ground.
Just down to hooking up wiring , all new lights front and rear, and finishing installing all new brake lines.
Questions? The car still has the push button start on the floor. Can I still use that?  Its been so long since I took it all apart...   The battery cable went from the battery to the switch, then another cable went from the switch to the starter solenoid? And is there another wire that goes from the switch to where, the ignition switch?    This is all very elementry stuff but I want to get it right.
Thanks, James
#2 Cooperman
  • 23,332 posts
Posted 12 November 2014 - 03:46 PM
Get a copy of the original BMC Workshop Manual which has a very easy to read circuit diagram.
You can still use the floor mounted starter switch, or change to an ignition/starter 'on the key'.
BMC Manuals are easy to obtain and there are several on ebay. The one you need is the one with the red cover.
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 12 November 2014 - 04:46 PM
is your 1330 a A series with the bendix starter ? then its easy to wire it as you describe, it wont be much use though with a A+ Pre-engaged starter though
#4 Larryville
Larryville
    Starting My Mini Up
  • 2 posts
Posted 13 November 2014 - 02:17 AM
Thanks guys for your help.
Its not an A+ engine,  about a 1972 vintage 1275 bored out.
I have several early books and manuals that have been helpful, an early Austin seven service parts list  manual that was very helpful in working on the body and interior.
James
