Rear Subframe Repair - After Some Advice ...
suspension
20 replies to this topic
#16 Sabre75
Sabre75
  • 21 posts
Posted 04 February 2015 - 01:26 AM
Right - tonight's update ... which should really have been at the weekend but I was tired!  -_-
So - Saturday night I realised the upper sections of the subframe arms where they join to the bulkhead beam were a little suspect too, so as I said I did some digging. One was entirely shot through so I cut out the tin-worm and Sunday morning made up another patch piece:
subbie_upper-patch by Sabre75, on Flickr
The other side needed some work, but it was only the overlapping piece that was knackered, so I cut it back and ground away the junk to allow me to butt-weld the 2 pieces back together. And yes that gap is a little wide in the middle - I was a bit gung-ho with the cutting disc there  :ohno:
subbie_upper-overlap-trimmed by Sabre75, on Flickr
So here's the patch plate plug- and butt-welded into place. As you can see the 'flat' upper section has been patched but I left the angled section as it was ok; I did seam-weld all around it though (including inside the arm) to prevent any water getting into the overlap and causing the same kind of problems again.
subbie_upper-patch-tacked-and-seamed by Sabre75, on Flickr
... and here's the other arm all welded up too; you can also see the seam-weld penetration from inside the arm ... and my foot.
subbie_upper-overlap-fully-welded by Sabre75, on Flickr
With all the main welds done I then seam welded all the flanges & edges inside the subframe around the areas I'd done the repairs; these weren't all perfect as it's tricky to clean the areas properly before you weld, but I got it done. One I've cleaned the frame for painting I'll go over all the seams with seam-sealer too, just to be on the safe side. But anywhere, here's where I am now - the subbie is all welded and hopefully won't need any more attention any time soon!
Here's the top of the frame:
subbie_upper-completely-welded by Sabre75, on Flickr
And here's the underneath:
subbie_lower-completely-welded by Sabre75, on Flickr
So apart from entirely rebuilding the top and bottom sections of both arms, the subbie was fine! - sealer and painting next ...
And Shawbags; cheers for that mate - I decided a while back that knowing how to weld would be handy, so I did an introductory evening course which I'd highly recommend to get the basics down and to learn the proper techniques from a expert. I then bought a cheap-y welder from ebay, which I wouldn't recommend. To cut a long story short the wire feed wasn't smooth so I could never run a decent bead, but I didn't know enough to realise that! Recently when my old machine died completely I went out and bought myself a Sealey MightMIG 150, which is a decent piece of kit and worth the £200 I paid. Apart from getting yourself a decent welder (and an auto-darkening mask; it's invaluable) it's just practice after that ... apart from the mini here's my practice piece ...
trailer_frame-in-progress by Sabre75, on Flickr
... extending my 3.65m trailer out to 4.4m (and totally rebuilding what turned out to be a very moth-eaten frame) - hopefully it won't snap in half once it's done!  O_O
Right - need to sleep again - cleaning, sealing & painting next - watch this space.
#17 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 06 February 2015 - 12:44 PM
Looks like you got the gas conversion kit for the MightyMig too ... how much extra was that?
#18 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 06 February 2015 - 01:48 PM
What a pleasure to read a well documented and photographed thread. Plus quality work.
Makes a pleasant change from "My Mini Wont Start" with no other info
Or "whats the best cupholder"!
#19 Sabre75
Sabre75
  • 21 posts
Posted 09 February 2015 - 07:23 PM
Evening folks - no more progress to report at the moment, or for a while actually as I'll be away from my projects for the next month! :'( - I just wanted to post a quick reply to the last few comments; Chopper - thanks for the kind words - this thread started off as "I think this'll work but am I missing something?" but then I thought I'd do it step-by-step; partly to show what I was doing and partly to keep my motivation up!
gazza; yup I have converted the welder to gas - I've heard nothing good about the gasless wire, plus all my experience was with gas. I bought a twin-gauge (bottle pressure & flow-rate) single-stage regulator from ebay for about £25 and the hose for about a fiver. The bottle is one of the 'hobby-size' (can't remember the actual code) BOC ones; it's about £20 a refill, but I have 2 as one *always* runs out on Saturday afternoon once every where's closed. I've also been told HobbyWeld do a good rental deal for us DIY-ers, but I need to look into that. Either way the proper regulator & refillable bottles are much better & work out cheaper than the throwaway ones.
I'm afraid there'll be no more until March now, but then it's frame repaint & refit with the -1.5deg camber kit =)
Bye for now,
Tom
#20 Sabre75
Sabre75
  • 21 posts
Posted 04 April 2015 - 08:12 AM
Morning folks  :-)
I thought it was about time I brought you up to speed on progress (whether you like it or not!). The subframe repair is now complete so after cleaning it up I gave it several coats of hammerite to keep the tin-worm at bay! Given the rubbish weather and low temperatures of late this did require the understanding of my family ...!
rear_subbie_painted by Sabre75, on Flickr
I'd like to tell you the frame is now back in-situ ... but sadly I can't. Since the frame was out I decided to underseal the rear 'well' where it lives, and that opened up a whole new can of worms!  :( I've started writing a project thread on it now (!) so I'll post a link to that here later.
Thanks for looking  :thumbsup:
Edited by Sabre75, 04 April 2015 - 08:12 AM.
#21 Sabre75
Sabre75
  • 21 posts
Posted 05 April 2015 - 12:29 AM
Evening - no wait - morning!  :blink:
If anyone's interested in what else I've had to do to the car of late, the project thread is now here: http://www.theminifo...ayfairsidewalk/
Hopefully it's interesting - and now I'm off to bed!  -_-
Also tagged with one or more of these keywords: suspension
