Best Answer Dan , 28 January 2015 - 01:00 PM
Sorry, red/white. Red/black is the left hand side and the number plate lamp. Go to the full post
Posted 28 January 2015 - 08:34 AM
The problem is that all the lights on the RH side side light curcit have stopped working, I have looked in the Haynes manual but my wiring dosnt seem to match any of the diagrams, any ideas on what's going wrong, any advice or help is greatly appreciated.
Posted 28 January 2015 - 10:17 AM
With each Mini should come a multimeter. If you don't have one, get one. I got mine from Maplin for £10.
Anyway I would start with the bullet connectors behind the front grill.
Check to see if you have power going in and coming out.
I had issues and found simply pulling the connectors apart, cleaning them and putting back together solved the issue.
But I had power going into the connectors, but not coming out.
Cheers.
Iggy.
Posted 28 January 2015 - 10:33 AM
Posted 28 January 2015 - 12:57 PM
Posted 28 January 2015 - 01:00 PM Best Answer
Posted 28 January 2015 - 01:10 PM
Posted 28 January 2015 - 01:56 PM
Posted 28 January 2015 - 04:09 PM
There is a small cluster of them by the air cleaner and another cluster behind the instruments. The sidelight fuse should be behind the air cleaner under the bonnet.
Posted 29 January 2015 - 08:08 AM
Posted 29 January 2015 - 08:12 AM
Okay thanks I have took a picture of the wiers and fusses looks like a bad case of previous owner syndrome but I'm un shore how to get them on here because I'm using my phone as I'm away from home still. Do you have a email I could send them too for your advice. Thanks again.
Feel free to e-mail them to me and ill post them up here for you. I have PM'd you my e-mail address.
Ben
Posted 29 January 2015 - 08:20 AM
Posted 29 January 2015 - 09:14 AM
Posted 29 January 2015 - 10:34 AM
You need to separate them out and clean the wiring to see the colours on the original cables properly, the colours of the spliced in sections won't help. I think we need to work out why you appear to have fuses in series with fuses because that's quite a bad idea. Myself I would remake all those with OE crimped inline glass fuse holders or maybe add another fuse box. It's a right mess. If you were closer I'd happily do it for you.
Posted 29 January 2015 - 10:50 AM
Mini Technical Sections →
Problems, Questions and Technical →
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Mini Spi Charging IssueStarted by Dutch_MiniSPI , 27 Mar 2024 electrical |
Main Dipped Beam Not Working - Just Before Mot :-(Started by Park , 24 Mar 2024 electrical |
Speeduino EcuStarted by cooperpooper , 09 Mar 2024 electrical, engine |
Smiths Electronic Speedo Accuracy?Started by chuee , 01 Mar 2024 electrical |
