I might get the Centre cap machined for a CMS yet.... But I'm really not sure...
Street Fighter
#751
Posted 07 February 2007 - 10:13 PM
#752
Posted 07 February 2007 - 10:14 PM
#753
Posted 07 February 2007 - 10:15 PM
#754
Posted 07 February 2007 - 10:17 PM
Its actully a clean pot, which has some 20/50 oil in... I couldn't find my oil can... so I used a Seringe, and a pot of oilWhat did you use the filler for ?
Jordie -
I think I might, after all, it can't cost that much...
#755
Posted 07 February 2007 - 10:21 PM
£7ish for the strap and bolts.
I paid a fiver for my main strap already done via ebay.
#756
Posted 07 February 2007 - 10:23 PM
#757
Posted 08 February 2007 - 07:20 PM
I love morspeed lol!
73.5mm Powermax pistons - 10cc dish inc rings...
Balanced A+ con-rods
Morspeed P3 cam (trackday)
and new core plugs
So all I need to do now, is nitromors the block ready to paint, and finished the edges, and I could have my short engine done this week
#758
Posted 11 February 2007 - 07:45 PM
Installed the crank again, but had a slight problem of the crank locking up once I torqued the caps down to 63lb/ft, so took it a part again, and found a slight burr, so file out, and wet n dry, tis fine now
Fitted the cam, it turns nice n smooth now I have got the correct end float.... Just need to fit the timing chain, and get a Dial gauge to time the cam in spot on
Tis all getting there... but I've still got plenty to build;
Doors;
Finish off cutting out the centres
Finish off the sliding window mech
Try and fit the doors to the Mini
Bootlid;
Fit re-enforcing panel to the back - as a boot liner
Fit Mk1 bits - Full number plate setup
Fit Mk1 bootlock
Fit Zues fasteners
Fit to Mini
Once the engine is installed
Front end;
Trim it up ready for lights
Trim for Grille
Set the height
Trim Skuttle panel areas
Cut off A-Panels
Then I think I'll only be a month or 2 off being ready for paint...
#759
Posted 11 February 2007 - 07:51 PM
Had my engine fire up today for the 1st time. After sorting out the dizzy (180out
Jordie
#760
Posted 11 February 2007 - 07:57 PM
I mean, I might aswell get the most accurate timing I can, after all... I do have an adjustable timing gears
and they do say, 1 or 2 degrees in one diaraection can increase/degrese torque/bhp!
So I'm going to timing it in best I can (infact I'll set it 1/4* shorter to allow for strech)
#761
Posted 11 February 2007 - 08:00 PM
Bill on the engine builder DVD keeps going too far in either direction, or cant work out which way to adjust it. haha
#762
Posted 11 February 2007 - 08:05 PM
I know, its funny that bit.lol, good luck at achieving that quater.
I wish they could of added the bit about installing the cam!
Would be most usful to me...
Well I still have alot more the pay out on the engine... ordered a new gearset, SC drops, a Rob Walker stg3 head, new clutch, and I am in the process of rebuilding my twins...
in which I am going to send the dash pots, a MG Rocker cover, and my Altanater braket off for Chroming
I've also got Megajolt to get, so going turn the old dizzy hole into an etra breather - I'm also considering a front mounted rad...
#763
Posted 11 February 2007 - 08:10 PM
#764
Posted 11 February 2007 - 08:36 PM
But I found I needed to install the timing plate, before finishing off tightening the cam...
I'm starting to collect blocks now too, mainly as a just incase measure, or if one day I get bored, I can build another engine....
#765
Posted 11 February 2007 - 08:38 PM
