Street Fighter
#886
Posted 12 March 2007 - 09:57 AM
#887
Posted 12 March 2007 - 10:21 AM
(_!_) - Insurance is about the same as any sports car - I want the Mini - I want it to be different - I want it to be fast, so I don't mind paying the price
Supermoto - their off the bike - afaik - I'll be using the bees knees in throttle bodies, the K1200RS, I think SC said their about 38mm - the best you can get on the BMW K bikes
Mad4Mins - Thanks for the heads up, but I am now sorted for head etc - like I said, I;ve got a K1200RS 16v head
#888
Posted 12 March 2007 - 10:24 AM
#889
Posted 12 March 2007 - 09:42 PM
Yeh I'll get my pistons back - thats no biggie, I'll ask shabs to send them to me...
I've also over come the urge to get a "sports" car now too, as I'm going to build the Mini to a N/a 1380 with a 286 cam - just because I'm am so bored of the Nissan!!
I'll build the 16v in the winter, pennies are a little short atm, and I'd rather have cash to "dispose" of, at a good cause... and NO - I am not changing my mind - for once - the Street Fighter will be a 16v A-Series, for the 2008 Shows
#890
Posted 13 March 2007 - 09:05 AM
to be honest I don't think I'll go back to morspeed now - SC are alot more informative, and are willing to help out wherever!!
Seems sensible to me Dog!
#891
Posted 13 March 2007 - 09:28 PM
£114 of that being a 286 Scatter cam!
But anyways;
Painted my engine today -
Me collectiong engines - still 2 other engines not pictured...
Nitromor's at its best - it burns too!
After a degrase, and a steam clean... a nice couple licks of yellow paint
Piston just placed in the bore - fits nicely!
Will keep updating with pics where I can, about how the engine is being built - I've got to collect my new box too...
3.44 Final Drive
Xpin Minispares Diff
SC TransX Drops gears - nice and whiney
Genuine BL GT Ratio Gearset
Oh and the over all colour of the engine - Yellow, and Red, with touches of black
#892
Posted 14 March 2007 - 08:15 AM
Ok I've just spent £200 with Minispares
Was thinking of going for the 296SP myself, but bottled it in the end. Unfortunately, when I bought the camshaft I couldn't afford the extra cost of the scatter cam and tried to be sensible by going for the MD286. Hope I don't regret it
At least I know I can change it easy enough at a later date.
#893
Posted 14 March 2007 - 09:53 AM
#894
Posted 14 March 2007 - 06:32 PM
ALos picked up myself some speakers
Infinity Refrence... 6x9 - yes 6x9's I'll be fitting these into the doors...
#895
Posted 14 March 2007 - 09:35 PM
So just been shopping
Just spent;
£1730.37 with Minispares - inc the 5% discount...
Should have this beast done by the end of May now
#896
Posted 14 March 2007 - 09:56 PM
#897
Posted 14 March 2007 - 10:14 PM
- GWP187 - WATER PUMP LATE TYPE CAST ROTOR NO BYPASS HOSE
- 47H5360 - LENS SCREW KIT MK1 REAR LENS
- GSD487 - SPEEDO CABLE 1990on(42.5")R/H/D
- C-STN236 - DAMPER LOWERED HEIGHT FRONT GAZ SINGLE
- S5400 - PLASTIC HEADLAMP BOWL KIT
- 21A1817 - STEADY ROD ENGINE UPPER.5"LONGER
- 47H5355 - LENS REAR LENS FLASHER MK I LH
- 47H5358 - LENS REAR LENS STOP/TAIL MK I LH
- 47H5362 - LENS REAR LENS FLASHER MK I RH
- 22A1881 - SPEEDO DRIVE 17teeth 10"WHEEL
- C-AEG420 - FLYWHEEL C-AEG421 STEEL TYPE BUT FOR PRE ENGAGED STARTER
- 56-9135 - K&N AIR FILTER HIF44 2 1/2 DEEP
- TIM011 - TACHOMETER IN POD 0-8000 BY TIM
- 21A2387 - TOP ENGINE STEADY BRACKET
- 47H5363 - LENS REAR STOP/TAIL LENS MK I RH
- YTA10037 - BATTERY CABLE LEAD 127"LONG
- GSY110 - CLUTCH SLAVE CYLINDER PRE VERTO GENUINE LL10469
- FAM3968 - CONE SPRING RUBBER ALL MINIS METRIC THREAD ONLY
- C-GRH002 - HOSE SILICON KIT
- AZX1818 - FUEL PUMP MECHANICAL
- R25RED - RAMPIPE HIF44 PIPERCROSS SHORT
- C-AEG481 - CLUTCH DIAPHRAGM ORANGE
- 500929MS - HEADLAMP RIM
- C-ARA4400 - RADIATOR KENLOWE LATEST HIGH SPEC ELECTRIC FAN
- 2A3720 - EARLY SPEEDO SPINDLE 6TEETH
- MSSK013 - BRAKE CONVERSION 12"TO 10"BRAKE KIT
- 14A7299 - GRILLE AUSTIN MINI MK1 WAVY TYPE
- 14A7780 - RETRO MK1 MOUSTACHE KIT COMPLETE
- DAH100590MMM - BADGE LATEST MINI WINGED BADGE
- LMA017 - ADAPTOR FOR TIM GAUGE WHEN FITTING OL PLASTIC OIL PIPE
- 22A598 - PRESSURE PLATE DIAPHRAGM CLUTCH TYPE PRE VERTO
- TP - OIL GAUGE "T" PIECE
- TYRE08 - TYRE YOKOHAMA A008 165/70/10
- C-AHT9 - OIL GAUGE PIPE BRAIDED 4'LONG
- AN154 - WIRING LOOM 1000cc MAYFAIR SIDE REPEATERS 86 ON
- GUG705554GM - GASKET ENGINE FRONT PLATE A PLUS
- K6836 - CRANKSHAFT WOODRUFF KEY
- C-AEG580 - CAM FOLLOWER ISKY TYPE HI-GRADE TAPPET SET
- C-AJJ3323 - DUPLEX CHAIN AND GEARS SET GENUINE AE CAST KIT,OE QUALITY
- MD286SPM - CAMSHAFT 286 SCATTER CAM A PLUS SLOT DRIVE
- WKN505 - CAMSHAFT WOODRUFF KEY
- 6K853KIT - OIL PRESSSURE VALVE AND SPRING
#898
Posted 14 March 2007 - 10:41 PM
#899
Posted 14 March 2007 - 10:47 PM
Got to remember theres 2+ of some of those too, for example my tyres - I ave 4 of them
#900
Posted 14 March 2007 - 10:50 PM
Love it when you talk sexy :blush:# 14A7299 - GRILLE AUSTIN MINI MK1 WAVY TYPE
# 14A7780 - RETRO MK1 MOUSTACHE KIT COMPLETE
Bing (1)
