Reliability For Austin Mini
brakes suspension electrical engine
6 replies to this topic
#1 jake2357
jake2357
    Just On Tickover
  • 8 posts
Posted 22 April 2015 - 05:20 AM
Hey Guys,
So I was wondering how reliable the engine, electrical and other parts in Minis are
And how could you make them more reliable and tougher so that they can easily handle rough roads, cold weather, daily driving, long trips etc.
Is there anything you can do or add to prepare the car so its able to handle some **** in its life and keep it running smooth and stronger for a long time.
I'm a college student state side in Texas (where its unpredictable weather) and take a 4 hour drive home every once in a while and am probably going to need to toughen up my mini a little bit over the summer.
Soon to be mine: http://www.kgfclassi...ils.php?cid=430
#2 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 22 April 2015 - 06:05 AM
As long as it's maintained correctly you should be able to throw it into any situation. Not sure about extremes of weather though. If you're doing a lot of motorway miles, expect it to be quite noisy.
#3 carthorse
carthorse
  • 257 posts
Posted 22 April 2015 - 06:46 AM
It's hard to work out from that advert what exactly that minis had done to it in the way of mechanical work. Very smart looking mini tho.
Not sure an 850 engine & big wheels is going to make it the ideal spec for a 4 hour freeway cruise though!
If you're committed to buying and the cars on its way, when it arrives find the nearest local specialist and get them to give the car a very detailed check over.
Electrics and ignition can be a very common weak point for day to day running so make sure that gets a decent check over - best of British luck!
#4 matt050990
matt050990
    I have upside down nipples
  • 1,199 posts
  • Local Club: Currently Ridin' Solo :)
Posted 22 April 2015 - 06:51 AM
That is a stunning looking mini mate.
Best bet would be service it regularly and don't push it too hard all the time.
As said on the other topic it's only a small engine so doesn't have much legs but is still a good bit of fun round the town.
Have you got anywhere to keep it in the poor weather?
Would be worth fitting an extra fan to help with coolant too.
Matt.
#5 spiguy
spiguy
  • 1,537 posts
Posted 22 April 2015 - 08:28 AM
As a member of our club told me when I went on one of my first big runs with the club, "minis can go anywhere". Based on some of the locations I have been with them, I would have to agree! Take care of basic maintenance, carry a few essential spares  - basically anything you can think of that would stop you dead, and that you can change at the side of the road .Carry a few tools that would allow you to do those jobs and also carry some spare fluids. Having done all that, I would go anywhere in a mini without any more (and maybe a bit less) concern than I would have in a modern car.
There is just so much less to go wrong in a mini, and they are actually really reliable in my personal experience of them. I think also because you are more involved with them through regular maintenance, and just paying more attention to any new sounds / smells etc, you tend to pick up on any issues that may be developing which gives you the chance to sort them before they become something that could leave you at the side of the road.
If it hasn't been done already, maybe changing over from points to electronic ignition would be a worthwhile move, and probably adding the ignition weathershield that was fitted to later cars would be a good idea. I have owned SPi's for years now which have them, and I have never had the old classic issue of rain water shorting out the electrics, despite driving in all weathers. They really do a good job of keeping the distributor and wiring dry.
But most of all enjoy your mini. I think you will have a great time with it, might be an adventure at times but it will be the making of lots of good memories.
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,063 posts
  • Name: Neil
Posted 22 April 2015 - 08:46 AM
Thats a pity i have moved from Peterborough otherwise i could have had a look at that.
It does look like a nice car but i do see oversills which would raise concerns for me. There are numerous threads about them on here. Can i ask what you have paid for the car???
Not being able to see from the pictures i wonder if there has been a front disc brake conversion done?? For long distances i would recommend getting this done. Standard drums can work ok but do need to be looked after. A disc conversion will be better in the long term.
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 April 2015 - 12:41 PM
Neil, That's exactly what i was going to write!
....Well apart from the first line...
Edited by Ben_O, 22 April 2015 - 12:41 PM.
Also tagged with one or more of these keywords: brakes, suspension, electrical, engine
