What Tools Do I Need?!
electrical engine suspension brakes
22 replies to this topic
#1 lanny
lanny
    Starting My Mini Up
  • 2 posts
Posted 20 July 2015 - 09:39 PM
Hi Guys,
Getting my first Mini (1991 City) in around 3 weeks give or take, and just wondering what tools/manuals/general bits and bobs I'll need that will last me, as opposed to waiting for a fault in my Mini to then throw money at cheap naff tools just because they were readily available at a local shop
Don't want to be spending ridiculous money, just something that will do the job and not break after a couple of uses!
Links would also be especially useful (UK websites only though please!)
Cheers!!
#2 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 20 July 2015 - 09:44 PM
An array of hammers, duct tape and cable ties.
#3 Icey
Icey
  • 1,552 posts
Posted 20 July 2015 - 09:50 PM
You won't go far wrong with the Halfords Pro ranges. I've got some which are over 10 years old now and they're fine (and I can be a bit heavy handed).
I'd suggest picking and choosing rather than buying one of the larger kits. If you're only working on just the Mini then some 1/4" and 3/8" drive imperial sockets, a set spanners and a good set of screw drivers will see you through most small jobs.
Specifically for Mini servicing - a set of feeler gauges (valve clearances), a grease gun (suspension component servicing) and a 1 1/2" deep socket (1/2" drive - wheel hubs and ball joints) will sort out 'major' service items.
The one single most expensive tool at this level you'll really need is a torque wrench. Again, the Halfords ones will do everything you need and are around £80-90.
What's that, £200-250 worth of tools? You'll save that in just a few services.
#4 Batmini
Batmini
  • 378 posts
IMPERIAL spanners and sockets
#5 Nuttoni
Nuttoni
  • 191 posts
  • Local Club: Basingstoke & Bournemouth
Posted 20 July 2015 - 09:52 PM
Don't forget WD-40!
#6 Carlos W
Carlos W
  • 10,114 posts
Posted 20 July 2015 - 09:53 PM
Get yourself a Haynes manual and read it.
(i've got a few, and I've never read any of them)
#7 peterjh
peterjh
  • 24 posts
Depending on what you have already you will need a decent AF socket set and spanners. Halfords stuff is fairly good. you will also need brake adjusting spanner and feeler gauges.
#8 RossKnight
RossKnight
  • 2,539 posts
Posted 20 July 2015 - 09:55 PM
If you want cheap imperial spanners and sockets, go to auto jumbles, or even car boots, they're always there for about 20p each
#9 DFulton
DFulton
  • 158 posts
Posted 20 July 2015 - 09:57 PM
about 15 years ago, I got given a "black forge" socket set.  It also included screwdrivers, pliers, a few spanners, allen keys, a Stanley knife and a few screwdriver bits (e.g. torx).  It's covered every job I've ever needed it for - not just the mini, but bikes and round the house too.
I can't find it online now, but this has most of the same bits (though it seems quite a cheap price).
Depending on what you're doing, you may also want these specific tools:
Torque wrench
Brake adjusting spanner
Oil filter wrench
Definitely get the Haynes manual too.
Edited by DFulton, 20 July 2015 - 09:59 PM.
#10 nicklouse
  • 18,678 posts
Don't forget WD-40!
Waste of money a spay that is not good at anything.
PlusGas.
#11 Ger Trude
Ger Trude
  • 19 posts
Posted 20 July 2015 - 09:59 PM
Yes they do a good range of lifetime guarantee items.
If you're in the motor vehicle trade, try and get a Halfords Trade Discount Card this may help and keep the cost down.
Edited by Ger Trude, 20 July 2015 - 10:01 PM.
#12 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,034 posts
Posted 20 July 2015 - 10:01 PM
+1 on the halfords pro stuff. And going to autojumbes etc there are usually good brands for cheap at them.
#13 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 20 July 2015 - 10:04 PM
Having bought a lot of Snap On, Beta, Teng etc over the years and thinking I ws buying the best; I'm totally a Halfords Pro convert now.
I'd suggest you look at their flash sales and get a small case of 3/8" and 1/4" mixed sockets to keep in the car. A set of feeler gauges is a must. Grease gun for at home. Screwdriver bit set. I never leave home without a Leatherman or similar. Also a pocket multimeter is cheap and small enough to leave in the car.
#14 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 20 July 2015 - 10:12 PM
I know this is my pet thing, Get A Multimeter Quick, you will need one, and download the How To Use A Multimeter in the FAQs Electrical Section, you can get one which is usable for your use for about £5 example http://www.ebay.co.u...=item3f3f9436c4
Perfectly ok for diagnostics
#15 lanny
lanny
    Starting My Mini Up
  • 2 posts
Posted 20 July 2015 - 10:23 PM
Cheers for all your help guys!!
Will definitely check out the Halfords range, would have otherwise completely overlooked it thinking it was just for punters!
Also tagged with one or more of these keywords: electrical, engine, suspension, brakes
