Possible Engine Seize
engine
21 replies to this topic
#16 Mrfleming344
Mrfleming344
  • 40 posts
Posted 15 August 2015 - 05:38 PM
Alternator bolt that apples pressure to the belt is also seized. Have taken the whole bracket off and dipped in oil for a while. Have a look in a few days and hopefully it will be free. Failing that I'll buy a new one.
Thanks for everyone's help, much appreciated.
#17 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 15 August 2015 - 05:56 PM
Well done mate. Alternator tension is adjusted by bottom bolt on a slider. Be careful when attaching it to the water pump make sure everything it lined up perfectly and tighten up little by little. Both my minis I have had when I got then had a lug snapped off the water pump that the alternator attaches to.
#18 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 15 August 2015 - 06:02 PM
After a little sorry a lot of forwards and backwards the crank became free to my delight. Fitting a new alternator now but can't seem to be able to adjust the tension on the belt. Is there a special tool. I have noticed the square fitting at the bottom which I believe is the adjuster. Just wondering how you adjust and what with?
Well done for persevering with this, your patience has given the right result!!!
#19 Mrfleming344
Mrfleming344
  • 40 posts
Posted 15 August 2015 - 07:42 PM
Well to be honest only tried it after getting some great tips from this forum. I'm going to subsribe now worth £5 all day long.
#20 Mrfleming344
Mrfleming344
  • 40 posts
Posted 20 August 2015 - 04:00 PM
Today I managed to fit the new drive belt and adjusted it after some fiddling. Unfortunately the engine now turns over but doesn't seem to try to fire. I haven't changed the leads yet do you think that would be the culprit?
#21 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 20 August 2015 - 04:13 PM
Plug in the ECU to a diagnostics unit, clear all codes and I would also check things like fuel pump etc...
Simply speaking, even though it's an injection you still need the basics, air, fuel, compression and a spark before an engine will run...
Have you switched the immobiliser off with the button fob ?
Has the fuel cut off been tripped ( press what looks like a big rubber switch on the RHS looking into the engine bay ) ?
When you switch the ignition on, do you hear the fuel pump prime pressure ?
#22 Mrfleming344
Mrfleming344
  • 40 posts
Posted 20 August 2015 - 04:33 PM
Well I think the battery is dead in the fob for the immobiliser. Didn't think it would turn over if the immobiliser was working. Didn't really listen for the fuel pump. Should I be able to hear it?
Where is the connection for the ecu?
To check the spark do I just remove one spark plug and place it against the block?
Sorry first bit of mechanics in years.
