Hi,
I recently took out the wiring loom (front half only) from my Morris Mini Mk1 1963 850cc. Then, I started the re-wiring process with new wires, with the intention to just start the car up. During this process, I also changed the setup from alternator previously installed to a dynamo + control box/cutout. Now, with minimum wiring and no extra electrical components installed (except battery, dynamo, control box, ignition coil, switch, distributor and fuel pump), I am able to start up the car - with the dynamo still disconnected from the control box. However, this will drain up my battery as it is not getting charged.
When I connect the dynamo to the control box, and turn on the ignition switch, after about 3-5 seconds, some smoke starts coming out of the dynamo. I immediately turn off the switch without attempting to start up the car again. Could anyone guide what could be the possible issues?
Further points to note: Please note that my car is a negative ground, so I have to polarize the dynamo to make sure it works correctly. When I connect a wire between the A terminal on the control box (battery power) and the field terminal of the dynamo (with the field wire disconnected from the dynamo), there is a spark, which I believe is needed to polarize the dynamo.
However, if I wire up the dynamo, and then try polarizing it by connecting the A terminal on the control box with the F terminal on the same box, there is no spark. Could this possibly mean that the control box is faulty? Is there any way to check the control box out of the car, as it is very hard to find a similar car here in which I could place it and check it out.
Feel free to ask any further questions that may help in diagnosing this issue.
Regards,
Mohammad.
