Kc530 Camshaft
engine
20 replies to this topic
#16 Dusky
Dusky
  • 5,322 posts
Posted 12 March 2016 - 06:38 PM
Try the calverst main bearing cap mod next time, cheaper and more effective than a main strap :)
#17 MRA
MRA
  • 7,607 posts
Posted 13 March 2016 - 01:29 AM
How is it different ?
#18 Dusky
Dusky
  • 5,322 posts
Posted 13 March 2016 - 07:32 AM
http://www.calverst.... cap issues.htm
#19 MRA
MRA
  • 7,607 posts
Posted 13 March 2016 - 11:04 AM
Are you talking about the 4 bolt cap ?  in which case it would require line boring, but on the plus side it is the best there is, rigidity and strength are the ultimate in main caps.
#20 Dusky
Dusky
  • 5,322 posts
Posted 13 March 2016 - 11:39 AM
read the article and what calver says about them.. the bit about the washers ;)
#21 MRA
MRA
  • 7,607 posts
Posted 13 March 2016 - 12:35 PM
The washers spread the load from under the head of the bolt, it's better to make the caps out of Meehanite 250 cast and heat treated, it makes it a lot stronger and because it is better cast material than the block it does offer a lot of advantages.
The main issue with some 4 bolt caps is that for some reason people assume that the outer 2 bolts have to be the same size, they don't, in fact 5/16unjf (J is required) is the best size because it offers the results that having 4 fixings is all about, and that is stiffness, this stops the cap from deforming as much as a standard
My steel straps are hardened EN8 and this stops the heads from "working" in to the strap, also offers a lot more stiffness, but in all cases they need to be line bored.
I find Keith's write up interesting, especially as my own 1380 turbo is running a standard cap.....
