Engine Juddering Alot!
engine suspension electrical brakes
7 replies to this topic
#1 Vinnienova
Vinnienova
  • 31 posts
Posted 27 October 2016 - 11:13 AM
My engine starts to judder alot in all gears after about 2 miles or so or when the temp starts to warm up. It mostly becomes apparent when I get to the first hill climb then just judders there after until I stop for half an hour then start off again will keep doing the same thing. I've checked all spark plugs and leads not them. Cleaned up contacts on ignition coil thought that had fixed the problem and then it's started agaon. Could it be a problem with the radiator? I've recently installed a used one as my last one developed a leak. Was thinking maybe this new used one has crap on it and some blockages on the vents are maybe causing the problem? Going to go and buy some redx and change some fuses see if that helps. Any advise on this matter would be much appreciated as I'm out and about and miles from home many thanks
#2 gazza82
gazza82
  • 3,018 posts
  • Local Club: TMF+
Posted 27 October 2016 - 01:07 PM
It is not going to be your rad!
Or fuses ...
Could be a whole host of other things from plugs, leads, coil, distributor, points, carb ....
#3 cal844
cal844
  • 9,639 posts
  • Local Club: TFMOC
Posted 27 October 2016 - 01:33 PM
Try changing the coil, also take the float bowl lid off, is there crud in the bowl?
#4 Vinnienova
Vinnienova
  • 31 posts
Posted 27 October 2016 - 01:47 PM
Going to change the coil at 4oclock when the part is in stock I think it could well be on its way out, will have a look at the float bowl not looked at it yet. Could it be a faulty connector from coil to dizzy as I've put a new spade connector on and seems to work better but still a slight judder it's definitely electrical, not the plugs will messs more thanks for replies will let you know as soon as it's sorted
#5 Vinnienova
Vinnienova
  • 31 posts
Posted 27 October 2016 - 03:23 PM
Changed coil and still happening mostly when o accelerate in all gears it's a quick judder jjjjjjjj as apposed to j j j j j if you know what I mean what the hell
#6 greenwheels
greenwheels
  • 689 posts
  • Local Club: Mini Fixers
Posted 27 October 2016 - 05:47 PM
Change the points and the CONDENSER. Make sure the dizzy cap is clean and not cracked, if it looks crappy chuck it.  Similarly the plug leads.   All that sort of stuff should never be allowed to get old.
Edited by greenwheels, 27 October 2016 - 05:50 PM.
#7 Vinnienova
Vinnienova
  • 31 posts
Posted 27 October 2016 - 06:02 PM
If I get a kit with rotor arm, points, condenser ec would it be a quite simple job and would I need to remove the distributer? Or if not would it effect the timing? Many thanks.
#8 cal844
cal844
  • 9,639 posts
  • Local Club: TFMOC
Posted 27 October 2016 - 07:12 PM
You can change points and condensor etc in place, no need to remove the dizzy
When it next misfires have a look at the rev counter(if fitted) does it spike(500-1000rpm) or stay constant??
If it stays constant its fuel, if erratic its electrical
After you solve this issue look into an electronic ignition kit
Also tagged with one or more of these keywords: engine, suspension, electrical, brakes
