Posted 21 January 2018 - 06:59 PM
Posted 21 January 2018 - 07:02 PM
Posted 25 January 2018 - 08:32 PM
Hi - I see nobody volunteered an answer.
Someone probably knows which colour is which (I don't happen to) but If you have a battery (or 12v power source of some kind) just earth the lamp body and connect each cable in turn to the positive to see which one is which (or you can connect it the other way round, as a bulb will work either way! - assuming they aren't LEDs)
A tip - if you are planning to scrap the MkIV (reversing light) lamps, cut the plug off the lamp (with most of the cable) and splice them onto the the Mk2/3 lamps then you can just plug them into the loom with no need to cut off the plug on the loom or otherwise mess the loom about (and then you can always go back to MkIV lamps more easily later if you wanted to) - you can then also use the existing spare cable off one or other (or both) plugs to connect to your chosen reverse lamp set up (but please insulate that cable if you don't use it, as it will be live whenever you select reverse gear!!!
Regards
Posted 25 January 2018 - 08:46 PM
Forgot to say
If I was guessing, I would say the red cable would be the tail light and the yellow(MKIV) or dark green(Mk2/3) would be the brake light but it will only take you a second to double check to be certain - Just to be clear, in your picture of the Mk2/3 lamp it seems to have two green cables - the one on its own is the indicator, I am talking about the one next to the red cable into the same bulb holder
Obviously different colours in the loom itself as you mentioned (Green/red LH or Green/white RH indicators, Green/purple-Brake light, Green/Brown-Reversing light
Regs
Posted 28 January 2018 - 11:00 AM
Posted 25 September 2018 - 08:01 PM
Posted 25 September 2018 - 08:47 PM
Just went to the shed to check my 1980 clubby estate for you. The battery input and output wires and the large brown and brown/blue go to the inner ring terminal(toward the centre of the car).
White red goes to the upper most large spade terminal as a trigger wire
Edited by cal844, 25 September 2018 - 08:52 PM.
Posted 25 September 2018 - 08:52 PM
https://www.ebay.co....d&ul_noapp=true
You can push 12v or add earth to anything you touch which would allow you to test wiring such as wiring up these lamps or anything else for that matter. There could be cheaper ones online. The newer PP also has a voltmeter on the front and LEDs to help see (good when you're on your back checking wiring under dashboards on newer cars)
Posted 25 September 2018 - 09:02 PM
Posted 25 September 2018 - 09:18 PM
For the starter you can use the original solenoid as a junction box or you can bypass it and put a relay in. If you don't put a relay or use your old solenoid then you may burn your ignition switch.
theres a few threads on it
http://www.theminifo...to-pre-engaged/
Posted 26 September 2018 - 02:41 PM
I’ve attached a picture of what I currently have and what I think I’m supposed to do? Can somebody confirm so I don’t have a Big Bang and fire LOL
Posted 26 September 2018 - 02:46 PM
#14
Posted 26 September 2018 - 06:14 PM
Thanks guys so the answer seems to be to use the existing solenoid as a relay. Makes sense. All I do is move all the wires over on the original solenoid. I have an alternator set up so there are a load of brown wires as well.
All your existing wiring needs to be moved over to the right hand post and terminal set. The white/red wire is extended to go to the solenoid (trigger wire when key is against the spring, to fire the solenoid)
#15
Posted 26 September 2018 - 06:19 PM
Move the heavy wire which goes to the starter to the other post.
White/red is then removed from the centre terminal and extended as the solenoid trigger wire
Broken Headlight Stalk On InnocentiStarted by IceBlue , 25 Aug 2025 ![]() |
Econoseal Or Something Else?Started by o0OWILKSO0o , 13 Aug 2025 ![]() |
Trying To Find The Right Wire Harness Online...Started by mattaebersold , 22 Jul 2025 ![]() |
Mini Rio 93 Boot Wiring IdentificationStarted by KanKanManKan , 11 Jul 2025 ![]() |
