Right, well a small update.
Me and Lew started to remove the engine today, we chose the hard way. We took off the front bumper, and the spotlights, and the grill and the weather was great, so i knew it was going to well.
So we were now ready to dump the oil and start work on getting the einge out and into my back garden!
"lewis, got your jack?"
"ah, i forgot it!"so a great start, no jack! then opened up my tool box got the spanners out, ah bugger! two 11mm spanners and no 10mm grrr!!
So no jack and no 10mm spanner, and then oh yep! nothing to put the oil in! Anyway manage to get a spanner and a tray for the oil (which ended up on the floor anyway due to Mr.careful himself (lewis)!
So we set to it. Hoses were ripped off, radiator went next then the alternator along with the dizzi cap leads etc etc.
Found out why the engine kept overheating.
1) The radiator was full of cr@p, but you would expect that of a 21 year old radiator!
2) One of the radiator hoses had got a little warm and melted an excape passege aka a hole! (im guessing thats NOT good)
3) The inside of the rad (which faces the engine, and not the passengers wing) was covered in oil, along with the rest of the engine.
So on payday, minispares will get an order from me for a new 2core rad, some hoses, and a fw other bits and bobs.
Anyway we carried on ripping the engine to pieces untill we got to the manifold!
See the link pipe had come away fro the Y piece just before it came off the road. And we couldnt get the Y piece off!
After abuot 30mins of faffing abuot with it, it was off.
And thats where we left it. Hopefully it may be out 2moro, if not, then it will be monday night.
All thats left to do is disconnect the gear linkage and the balljoints then lift it out.
I think i might need to clean all the "fluffy" looking oil off so i can get to bolts etc.
also have a look on
www.myspace.com/worcesterretroand add us, Dan (JetBlick) has been playing about with it, as his myspace is so amazing! (he has one picture, and its of a silver transit van?!!!)
