Supercharged Bmw K Head Conversion
99 replies to this topic
#61 johnK
johnK
  • 66 posts
Posted 06 October 2007 - 07:07 PM
nice to see you making progress there - lovely little heads to work with!
smoothing the "throats" out pays very large dividends on these heads.
looking forward to seeing more progress soon. cheers
JK
#62 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 06 October 2007 - 07:19 PM
i went to start decoking the ports and they are very small to work on, really the only port work iv done before is on a kent crossflow engine and thats 8 valve the ports leading up to each valve are a nice size and could easy get lil tool in there...start on the 16v head ok can get to the very entrance of the port bt when it splits for each valve...well put i like this...its gona take a while and im gona have to get a small tool
not to worry tho its gona be a while till its fitted so im better off spending my time making sure its tip top.
is there any advice about where to smooth etc or really what not to touch (other than valve seats)
Thanks for your interest :kiss:
David
Edited by mini93, 06 October 2007 - 07:19 PM.
#63 wolfys_mini
wolfys_mini
  • 2,493 posts
  • Local Club: many!
Posted 06 October 2007 - 07:24 PM
if you asked nicely im sure jim at college (the cleaner lol) would advice you better
#64 Matt
Matt
  • 4,703 posts
  • Local Club: The mini forum - i live here
Posted 06 October 2007 - 07:27 PM
looking good!!
#65 mini93
mini93
  • 8,615 posts
Posted 06 October 2007 - 07:30 PM
might be little different on the k1100 than the pinto engine he did while i was there...the ports really do seem small lol
im not trying to remove any material from the ports mostly... but really just take out the feel from the casting, the slightly rough one will cause lots of passing friction
i might just do it by hand in the end (in a very smutty action im sure) lol with lots n lots of emery paper then move to wet n dry and then special polishing paist they have in the diesel section :kiss:
jonh K do you think the LT cams would be up for forced induction? or would custom ones be muchos better?
#66 wolfys_mini
wolfys_mini
  • 2,493 posts
  • Local Club: many!
Posted 06 October 2007 - 07:31 PM
he knows what he is on about though...better then everyone else lol
#67 johnK
johnK
  • 66 posts
Posted 07 October 2007 - 05:47 PM
yes the LT cams will be really nice for forced induction as there is very little overlap to the stock cam timing - perfect for charged engines. The LT cams also have reasonable lift at 8.8mm so will work really well with a ported throat head - I'll dig some pics out for the throat areas when worked. The other essential piece of machining to have done is 3 angle valve seats. As stock the K heads have really wide valve seats but thin seat area - hence a lot of wasted material on the valve seat which does not help flow.
cheers
JK
#68 mini93
mini93
  • 8,615 posts
Posted 07 October 2007 - 06:06 PM
kinda just noticed thay have large seating area, just been decrapping (lol) the inlet valves. the exhaust ones are too hard when i have a headache so will give em a go tomorrow
for now..
ill clean the actual seats when i come to reassemble i have some valve paist some where
#69 mini93
mini93
  • 8,615 posts
Posted 07 October 2007 - 06:07 PM
also yay, just what i suspected about the LT cams. looking forward to the piccys of the throats
#70 mini93
mini93
  • 8,615 posts
Posted 08 October 2007 - 08:10 PM
done a lil bit today aswell (gona run out of stuff to do soon enough :D )
riiight well did the exhaust valves tonight, they take alot longer than inlet all the carbon actualy bakes itself to the stem, used an old sharpened screwdriver and a pencle sharpener blade lol i held the stem in the chuck of the drill n spun easy to do and works well, in the end i made it nice n shiney with a bit of emmery paper and wet n drive really made it shine
again ill do the valve seats when i come to reassemble the head :kiss:
should be able to see here how crapped up the exhaust valves get
can really see here what the underside is like, this can cause hotspots inside the compustion chamber leading to pinking...which we dont want!!!! at all
Did a little bit of porting on the inlet port aswell, not really finished yet i need my grinding stones so i can get in from the chamber side making very sure i dont touch the seats! They already feel so much more smoother than standard
can see at the back end of the port where its still rough and the casting surface
the standard port, all the casting marks still there, can see why the air flow could be reduced
tis all for today, i got a headache from hearing the drill yet again. hopfully ill remember to bring my griding stones home from work then i can work from the chamber side and do the rest of the ports (will have to yoink more emmery paper :cry: )
#71 mini93
mini93
  • 8,615 posts
Posted 09 October 2007 - 08:25 PM
:lol: kinda thinking about sending the head off to be ported and gas flowed :) if i do so i know that all the ports are going to flow equaly which, of course is always a bonus
also been talking with my friend tonight about plenum chambers, throttle bodie to valve distaces and how that will effect the point of maximum torque
#72 Grimmy@JHE
Grimmy@JHE
  • 759 posts
  • Local Club: tmf
Posted 09 October 2007 - 09:11 PM
i was under the presumption that individual throttle bodies were prity muck useless on forced induction.
surely a single would be easier? plus if the plenum chamber has just one butterfly, surely flow would be better then there being a butterfly on each cylinder? or does it give better mixture control?
but on another point i love the project and i bet your loving the shopping.
i had a lesson the other day on plenum chambers, air box's and general airflow. was very interesting.
anyway good luck!
#73 mini93
mini93
  • 8,615 posts
Posted 09 October 2007 - 09:21 PM
well the injection unit is actualy built into the throttle body unit
behold, at width of 35mm awesomeness!!
#74 chairchild
chairchild
  • 606 posts
Posted 09 October 2007 - 09:27 PM
now they look quite cool!
whereabouts did you get them from, and what kinda cost where they?
#75 mini93
mini93
  • 8,615 posts
Posted 09 October 2007 - 09:35 PM
not got em yet :lol: not yet on the high priority list
link the throttle bodies are on there, various sizes, they have a weber manifold stud flange aswell, different types on there also
