Supercharged Bmw K Head Conversion
#46
Posted 22 September 2007 - 08:39 PM
when thats done i can mask up al the surfaces that need to be kept smooth (valve seats and the deck etc) and blast it at work basicly just to get a nice clean casting, should look nice lol
not sure if work mind but oh well im doing it anyway lol
#47
Posted 23 September 2007 - 12:12 AM
#48
Posted 23 September 2007 - 10:51 AM
just how about supercharged twincam?
thankies
#49
Posted 23 September 2007 - 11:37 AM
cheers minisprocket!!
No worries mate
Now heres a picture of my work in progress, again
#50
Posted 23 September 2007 - 12:04 PM
is the pipe welded to the cover a breather?? and the one from the head oil return to the block?
also
i need to get the booklet from specialist components!!!! should make good reading indeed
Edited by mini93, 23 September 2007 - 12:05 PM.
#51
Posted 23 September 2007 - 02:35 PM
Another breather is coming off the top of the oil filler cap and both the one on the head and the filler cap are being routed to an oil catch tank. Both these are 25mm OD
#52
Posted 23 September 2007 - 02:39 PM
#53
Posted 23 September 2007 - 02:41 PM
#54
Posted 23 September 2007 - 06:55 PM
I'm planning on fitting the oil drain from the end of the head, when I eventually get the time to start building mine, but just thought I'd check.
cheers
#55
Posted 23 September 2007 - 07:22 PM
At the end of the day iys up to you, as to what is totaly necessary. I will be using this one and one on the end cover only.
#56
Posted 24 September 2007 - 09:01 PM
#57
Posted 24 September 2007 - 09:14 PM
sumone i knew was talking about developing there own sequential system, but unsure if thats going to happen due to somthing thats recently happened, he was saying he wanted my rally car to be a testbox...however that could cost me alot of money on the rally car if it goes wrong at about £300 a single venue entry free and then if it decided to take out other components in the engine at the same time, could be expensive test indeed.
if i do go for test ill be checking everything, making sure everythings secure that the switching unit isnt going to blow apart somehow alowing debris to float into oil passageways
straight cut drops, not sure of the ratio, ill be going for which ever helps use of the dogbox, dont want the gearbox spinning faster than the crank speed
going to run ATB diff, might utlise equile length drive shafts but thats going to be a decision close to the time of perchase and 10 inch wheels
Edited by mini93, 24 September 2007 - 09:16 PM.
#58
Posted 25 September 2007 - 01:26 AM
#59
Posted 25 September 2007 - 07:26 PM
it also makes me want to get it done asap which is a problem as i wont have my shell ready put it
hmmm i almost feel a shopping list coming on lol
Edited by mini93, 25 September 2007 - 07:27 PM.
#60
Posted 06 October 2007 - 11:50 AM
snapped a few piccys of the ports and stuff aswell
inlet valves removed (little blury)
and inlet ports
exhaust valve removed
and the exhaust ports
a nice view of the chamber aswell with the valves removed
piccy of the valve spring seat and valve, the rubber seat is still in place (i can imagin not being able to find new ones if i damage them acidently)
also at work i decided to clean the cam cover, so shot blasted it all nice down the metal filled in some dents with metal set bit of primer n rub down and back to work for some black paint, going to rub it down again this weekend and then get another layer (or i might buy some shinier stuff)
piccy:
also a piccys of the valve components:
i might clean up the ports this weekend aswell, just decarbonise them might make them a little smother aswell
