Let the Butchering Begin
#136
Posted 25 July 2007 - 10:17 AM
the watsons frame and the 16vminishop are both doing them without needing an extended front
reason for the extended front is slight more room on the bulk head... *weber box will do the same*
but the oil filter and the alternator touch the front.
resolved by relocating alternator and using a remote oil filter housing.
#137
Posted 25 July 2007 - 11:09 AM
The watsons frame which fits under and unmodified front is actually a K-series frame adapted to take the B/D series engines (Honda). Im extending the front as i'd prefer to have lots of space free rather than cram it right in. The rad i got is huge and my next mods might need space around the exhaust manifold
Another thing i would do if i started this project again... cut the front crossmember off the K-series frame and make it 3-4" shorter
#138
Posted 25 July 2007 - 11:24 AM
so i am right in the sence it will fit without extending the front end..
just need a few bits and bobs to be moved around and it would be quite a squeeze.
but will it go in.. even though i have a more or less standard front end.. albeit less the inner wings
#139
Posted 25 July 2007 - 11:48 AM
Standard K-series in an unmolested round-nose = no, unless its built like a tardis..
#140
Posted 25 July 2007 - 06:25 PM
#141
Posted 25 July 2007 - 06:29 PM
but wasnt sure about going in a standard front....
but with a normal subframe... you dont need to take the front off to get a mini subframe out?
so why any different with the k series?
#142
Posted 25 July 2007 - 06:32 PM
are the k series engines not wider and require some "trimming" of the inner wings. would it also fit through the bonnet hole? could always lift the shell over the subframe thoughbut with a normal subframe... you dont need to take the front off to get a mini subframe out?
#143
Posted 25 July 2007 - 07:21 PM
with some very nice paint over the top.. so im reluctant to pull it apart.
and i wouldnt mind taking off one subframe... and then lifting the body over the top of it.
#144
Posted 25 July 2007 - 09:52 PM
I think it was in miniworld, not 100% sure though.
#146
Posted 26 July 2007 - 11:56 AM
and they have
#147
Posted 26 July 2007 - 12:45 PM
#148
Posted 26 July 2007 - 12:49 PM
I WANT TO FIT IT WITH THE FRONT END STILL ATTACHED!
#149
Posted 26 July 2007 - 12:52 PM
#150
Posted 26 July 2007 - 12:54 PM
sorry dave.. as you were
