Let the Butchering Begin
274 replies to this topic
#196 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 27 August 2007 - 09:46 AM
This is a rat, see any comparison? Me neither
That thing's brilliant! It's now my new background! ;D
#197 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 06 September 2007 - 04:21 PM
Back from the ring, no more galavanting about.. its time to get it ready for next years run!!!
#198 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 06 September 2007 - 07:22 PM
Lol excelent sig Dave!
#199 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 10 September 2007 - 02:59 PM
Brakes Update:
Much isnt said in the way of the braking system when converting from mini to metro. As i have found, the mini and metro parts arn't compatible (to sum it up).
Using the mini brake master cylinder with late mini rear wheel cylinders (19mm) and metro gti front calipers just dont work! Some have has slight success with using van rear cylinders (12mm) to increase braking pressure to the front and some have tried bias valves. The conclusion for each method was the same, although there is improved braking it seems that it was still considered appauling.
Ive had nothing from my brakes.They're completly useless so after replacing the rear shoes, adjusting it all up and re-bleeding th system i found that i had some form of stoppage but the pedal was already touching the floor!!! Sod that!
With the mini master cylinder, Metro front calipers and van (12mm) rear wheel cylinders my brake test at the mot came back at a whopping 14% efficiency. To put it into perspective, my handbrake gave me 22% efficiency :o
Ive ordered up a Girling 0.625 Master Cylinder with remote resivour and braided lines to suit. All in to fit a mini was £50.35 delivered and ive been told this will sort the braking issues i have because of the enlarged bore of the master cylinder. I cannot take credit for this method as Geehawk on www.theclubman.co.uk was the first to do this.
Using this method eliminates the bias regulator for the rear brakes too, so later on i might install a valve to reduce braking pressure to the rear.
Next thing on my list is to get the arches sorted, and take it to AJ's for some mapping. After that i should be able to stick it in for another MOT. Fingers crossed she'll be ready for castle Combe... :P
#200 Pie
Pie
  • 7,695 posts
  • Local Club: GoGoAuto
Posted 11 September 2007 - 03:39 PM
Good lad dave. dotn give up on dilly.
Im really fed up with my mini at the moment. I think its time for a complete engine out, strip down, deck the block, and rebuild. :xxx: just dont have the time or money :w00t:
#201 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 11 September 2007 - 05:17 PM
They arrived today, :w00t:
I got a PM from custom minis about a special order of miglia arches which are a whopping 8" wide!!!! so we'll see how this goes :xxx:
#202 nag1_uk
nag1_uk
    Ring Runner 2005
  • 227 posts
Posted 11 September 2007 - 08:09 PM
I am considering this for my pickup. Is this just for a single system or a split system?
I would like to have seperate circuits for the front and the back if possible. Would I need 2 of those master cylinders with a bias bar? Or can you get a .625 2 way master cylider?
Cheers for any help!
Mike
#203 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 11 September 2007 - 08:19 PM
Hi mike.
It seems they only have single output. Mind you they do a bias bar and racks for twin master cylinders etc so that would be just as good.
check them out, the best prices ive found and delivery was spot on next day.
www.compbrake.co.uk
hope that helps..
#204 nag1_uk
nag1_uk
    Ring Runner 2005
  • 227 posts
Posted 12 September 2007 - 07:21 AM
Hi mike.
www.compbrake.co.uk
hope that helps..
Cheers but I had seen the link on the 16V forum. But thinking about it I do not think I need that master cylinder as I am still using the metro 4 pot front brakes for now.
#205 Jammy
Jammy
  • 25,397 posts
Posted 12 September 2007 - 09:31 AM
8" wide miglias!! :xxx:
#206 THE STIG
THE STIG
    Da stig says, GO GO GO
  • 2,506 posts
Posted 12 September 2007 - 07:09 PM
thats what i am running and the pedal is very low before the brakes kick in looking at changing the rear cylinders if that does not work looking at a twin master cylinder set up
theres one for sale in the z cars section
#207 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 25 September 2007 - 12:33 PM
Had a strange parcel turn up today when i got home... "hmm, i dont remember ordering anything!" :wub: got inside and opened it up. O....M.....F.....G!!! Its my new arches. sweet!
Big Big thanks to Custom Mini's for doing me a set of 8" wide miglia's, if these dont cover it then i dont know what will :dontgetit:
#208 mighty_mini
mighty_mini
    Sambo Spoon
  • 2,499 posts
Posted 25 September 2007 - 12:36 PM
#209 CharlieBrown
CharlieBrown
  • 6,587 posts
Posted 25 September 2007 - 12:41 PM
Holy cow there massize.
And well done for using a 15 rated DVD becasue its a family forum! :dontgetit:
#210 Tom Booth
Tom Booth
  • 822 posts
  • Local Club: TurboMinis.co.uk
Posted 25 September 2007 - 12:44 PM
Jeeeeeeeeeeesus christ there rediculous!
