Updating Points Distributor On M.e.d 1380
engine electrical
6 replies to this topic
#1 Howie1000
Howie1000
  • 124 posts
  • Local Club: Cornish Mini Club and Mini7
Posted 06 October 2019 - 03:53 PM
Hi guys,
I’m slowly getting around to piecing together my very old MED 1380 engine for a rebuild.
In my Clubman at the mo is an MG Metro 1275 engine with electronic ignition, nothing fancy, just bog standard Metro dizzy.
On the 1380 it’s an old dizzy with points. What is a good upgrade for this that won’t cost a fortune?
Coil pack with no dizzy? Electronic ignition with dizzy but no points?
(I’ll be running a Weber carb, no injection or ecu’s etc)
All suggestions and advice welcome ??
#2 MK1russ
MK1russ
  • 50 posts
Posted 06 October 2019 - 04:08 PM
The standard metro electronic dizzy with the advance curve suitably modified for the 1380 engine.
#3 nicklouse
  • 18,596 posts
Posted 06 October 2019 - 04:11 PM
if the dizzy has been set up with the right springs and advance for the build i would only change it to a pointless set up.
otherwise you will need to be spending quite a bit of money.
#4 Howie1000
Howie1000
  • 124 posts
Posted 06 October 2019 - 04:16 PM
The dizzy I have is the one that came with the engine from MED in 1991, I’ve had it in storage for years. Can that dizzy be converted to pointless? Cheers
#5 nicklouse
  • 18,596 posts
Posted 06 October 2019 - 04:18 PM
should be easy. if MED supplied it then i would ask them to convert it and maybe adjust the curve for modern fuel if needed.
#6 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Posted 06 October 2019 - 04:20 PM
You can, it would actually be easier to recurve and rebush a 65D type as it's already electronic and usually more reliable than the kits
#7 cal844
cal844
  • 9,623 posts
  • Local Club: TFMOC
Also tagged with one or more of these keywords: engine, electrical
