The "wok" (For Those About To Wok.....sorry, Very Poor)
53 replies to this topic
#16 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 08 April 2021 - 09:34 AM
If its from the bottom edge then it does indeed sound like the gasket...
This thread might explain the oil hole better
https://www.theminif...pot-what-is-it/
Thanks. A useful link. I'll look for the hole. I've removed the starter. It's dry in there. Rocker cover gasket also seems dry and not leaking down from there. Should that mysterious hole have a dangly pin in it as the earlier post or should it just be a hole? Is it intended to act as an overflow pipe to warn of oily issues unseen within?
#17 Colinmac1330
Colinmac1330
  • 273 posts
Posted 08 April 2021 - 09:40 AM
I did this a few weeks back, it is possible but wasn't easy. In hindsight I would have taken the engine out.
#18 ads7
ads7
  • 351 posts
Posted 08 April 2021 - 11:11 AM
Unecessary imo. I just undid the engine mount jacked the lump up a little then used a normal spanner.
Slim fingers help.
Leave the bolt at 7 o'clock out when reassembling as it's a pita
#19 Colinmac1330
Colinmac1330
  • 273 posts
Posted 08 April 2021 - 12:05 PM
I mean the clutch housing between the block and wok, not just the wok itself.
#20 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 08 April 2021 - 01:49 PM
Any tips, any things to look out for?
#21 Colinmac1330
Colinmac1330
  • 273 posts
Posted 08 April 2021 - 02:56 PM
Forget the swear barrel and get a swear skip  :gimme:
I would just strip as much as you can around the engine, i had to get the clutch side raised as high as I could to enable me to get the housing out.
As someone else said remove the radiator and possibly the exhaust/manifold depending what setup you have. I never done this but it would definitely make it easier.
It was a real PITA though to do and as I say if I was to do it again I would pull the engine.
#22 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 08 April 2021 - 03:19 PM
Skip ordered
Exhaust manifold and all the gubbins at the back....already off and out
Radiator next
I don't have an engine hoist or a garage
Just me, the drive and the elements, so I'll battle on
Thanks again
#23 Colinmac1330
Colinmac1330
  • 273 posts
Posted 08 April 2021 - 03:31 PM
It is do-able, just frustrating at times but you will get there.
#24 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 11 April 2021 - 03:17 PM
The PITA wok bolt from hell just won't budge
All weekend
In all weathers
Including hail and snow
Bent spanners
Engine mounts disconnected, engine raised an inch or two
Access, just about
But it won't budge
All I've managed to do is round off the bolt head
I suppose the only option is now is to work out how to lift the engine out?
Any last words of wisdom for a tired old fool?
#25 nicklouse
  • 19,058 posts
Posted 11 April 2021 - 03:22 PM
Put some bolts back in.
#26 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 11 April 2021 - 04:58 PM
bolts back in
no change
rounded bolt head
it's not budging
#27 Maccmike8
Maccmike8
  • 1,101 posts
Posted 11 April 2021 - 05:54 PM
Get some of these for when the engines out https://www.amazon.c...440078527&psc=1
#28 Pops_Guild
Pops_Guild
  • Just Joined
  • 363 posts
Posted 11 April 2021 - 06:54 PM
I’ve had great success with Crack-it spray on bolts that won’t budge...
https://www.mytoolsh...s&siteid=196673
#29 weef
weef
  • 557 posts
Posted 11 April 2021 - 07:06 PM
If you are really stuck you can drill a hole large enough to get a socket extension bar through in the subframe/ inner wing dependent on how it aligns with the offending bolt, adjust the height of the engine to what suits best,  and use a socket to unscrew it. A decent 1/4 drive set should do the job or even a 3/8 set would not require too big a hole.
#30 weef
weef
  • 557 posts
Posted 11 April 2021 - 07:07 PM
