Littlegreenmini Prep And Refinish @ Mill Road Garage Iow
160 replies to this topic
#46 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 09 June 2021 - 07:38 PM
Time to get the outside ready for paint now.
First step is to sand the primer.
I sprayed a light coat of black paint over the primer to act as a guide coat. This will allow me to keep easy track on the level and show up any imperfections
Roof first
And then I worked my way around the rest of the car flatting one panel at a time.
And then once finished, I removed the paper masling and cleaned it down.
I think tomorrow will probably be fitted fitted arch trims which need holes drilling and riv nuts installing and then I'll paint the roof and prep the doors.
Ben
#47 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 10 June 2021 - 07:42 PM
I painted the roof today
There was more progress but I'm short on time to upload this evening so will do so tomorrow.
Ben
#48 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 June 2021 - 08:13 AM
Here is the rest of yesterday's progress.
I did the last of the sealing up
And then set to work on the arches. I believe they are ST style group 2's
You have to cut the arch where it fits over the body seam which i had done in that picture
Then I got some m4 pan/washer head machine screws and riv nuts.
I used some suitable sized washers to lay into the recesses for the screw holes so i could replicate the position of the screw head and get a centre mark to drill and used spray paint to mark the positions
And then drilled them.
I had some issues with most of the arches where the reinforcing around the screw hole locations hadn't been cast properly so once I began drilling they blew due to air bubbles in the fibreglass so that had to be repaired.
But once they were, I could start fitting them to the car.
Just a simple case of offer them up and then mark the positions of the screw holes, drill and then install the riv nuts.
There will be a rubber seal between the arches and body when they are fitted after paint.
Ben
#49 MikeRotherham
MikeRotherham
  • 1,030 posts
Posted 11 June 2021 - 09:41 AM
I like the way these arches are attached to the body and the idea of the rubber seal between.
Easy to remove when checking behind for dirt or rust.
Edited by MikeRotherham, 11 June 2021 - 09:43 AM.
#50 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 June 2021 - 04:10 PM
And that's the colour on.
And then unmasked
Ben
#51 Viktor
Viktor
  • 658 posts
Posted 11 June 2021 - 08:21 PM
Beautiful!
#52 colinf1
colinf1
  • 1,081 posts
Posted 11 June 2021 - 09:37 PM
Look at that shine.. amazing finish straight out of the gun!
What timeframe would be between last coat and unmasking?
#53 sonscar
sonscar
  • 3,247 posts
Posted 11 June 2021 - 10:10 PM
I try to unmask while the paint is not fully dry to prevent it pulling off,be nice to know if this is needed,Steve..
#54 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 11 June 2021 - 10:59 PM
I removed the masking about 20 minutes after applying the last coat of clear. In the conditions of the booth, the paint is dry enough to lightly run a hand over but still soft enough to mark it with any pressure so I have to be very careful.
I mask the car in such a way that I can simply push in gently on the masking film and it comes easily away.
As Steve has said, it's best to remove masking as soon as possible. I never leave a car masked overnight  after painting and definately like to damask whilst the booth is still hot as not only is it more difficult to remove if left, you risk damaging the paint edges when you peel the tape away.
This is especially a problem when using soft edge foam as if you leave it too long after the paint is cured, it will leave behind a hard crispy line of foam all along the edge ot the paint which is disastrous.
As a general rule of thumb, keep checking your paint after you are finished by pressing a finger lightly onto the overspray on the masking directly next to the last bit you painted. If it feels sticky or easily leaves a finger print, leave it a bit longer.
Always remove carefully and don't take any risks. You do need your wits about you. Once I removed the film masking sheet on a job adjacent to the panel I painted and I wasn't paying enough attention and it billowed back on itself and stuck to the fresh paint. If that happens, you are in for a world of pain as not only can you not save the paint, the film is a nightmare to remove before you can flat back and start again.
I think I started to waffle a bit there!
Thanks for the compliments on the finish.
Ben
#55 wingnut
wingnut
  • 468 posts
Posted 12 June 2021 - 08:12 AM
As always Ben,a great job.No wonder you've always got plenty of work on
#56 Mr Brum
Mr Brum
  • 28 posts
Posted 12 June 2021 - 08:23 AM
Great work Ben, looking lovely as always!  Are you fully rebuilding this one or returning as a rolling shell?
#57 slyrmini
slyrmini
  • 278 posts
Posted 12 June 2021 - 08:57 AM
Mega! Paint job looks lovely.
Best bit next, building it back up and putting all the shiny bits on.
#58 surfblue
surfblue
  • 1,829 posts
Posted 12 June 2021 - 09:09 AM
Looking lovely, very similar to the 'Racing Green' edition. My mate had one but he was a bit of a crash test dummy, his was rebuilt and repainted several times, remember seeing it being painted on one occasion standing outside the spray booth. Great skill involved. Do you do all the work yourself or have you employees?
Edited by surfblue, 12 June 2021 - 09:09 AM.
#59 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 12 June 2021 - 10:47 AM
Thanks, it is pretty busy at the moment.
Thanks.
I won't be rebuilding this one, I shall refit the steering rack, column and sibframes and then it will be going back to the owner for fit out.
Cheers.
Hopefully we will see the ongoing progress by it's owner once he has it back.
It does look similar to racing green but is a fairly unusual shade. I think it's a great colour, especially with the OEW roof.
I don't have anybody working with me currently so I do every one of my restorations from start to finish by myself.
I have tried out people in the past but have had no luck finding someone reliable.
I am I'm the process of adding onto the workshop by knocking through into a neighbouring unit to create a fit up bay and double panel work bay.
Once that is complete, I will be looking again for someone to come and join me.
Ben
#60 Sam76
Sam76
  • 40 posts
Posted 12 June 2021 - 01:49 PM
Now that’s a job I would jump out of bed every morning to go to!!
I’d even move house lol
