Steering Column Cluster
electrical
11 replies to this topic
#1 p.b.r.
p.b.r.
    Starting My Mini Up
  • 4 posts
Posted 30 May 2021 - 05:08 PM
I'm wondering where this purple wire connects. 1988 Classic Mini.
Many thanks in advance for guidance.
#2 gaspen
gaspen
  • 980 posts
Posted 30 May 2021 - 05:16 PM
I don't see where should it connected but the Purple-Black wire is for the horn.
#3 Richard_
Richard_
  • 239 posts
  • Local Club: ISMOC
Posted 30 May 2021 - 06:12 PM
Yes it's the horn. There should be a bullet type thing on the end which goes deep into a recess down between the blue/red and blue/white.
#4 splintercat
splintercat
  • 616 posts
Posted 30 May 2021 - 08:16 PM
yep horn all the way
#5 Spherix
Spherix
  • Just Joined
  • 479 posts
  • Local Club: Mini Seven Club Netherlands
Posted 31 May 2021 - 07:04 AM
Here you go, combined with black on mine:
#6 Vanman20
Vanman20
  • 274 posts
Posted 31 May 2021 - 07:08 AM
The OP's is connected the same as yours,the unconnected wire is purple and black
#7 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 31 May 2021 - 08:25 AM
CAREFUL!
Won't be combined with the black .. that purple wire will be separate behind the black .. black is the switch earth wire.
#8 Spherix
Spherix
  • Just Joined
  • 479 posts
Posted 31 May 2021 - 11:10 AM
Ah good point, the connector is so deep it seemed joined to me. Couldn't easily pull it out either.
#9 Spider
  • 15,141 posts
Posted 31 May 2021 - 06:38 PM
I'm pretty sure that wire goes up inside the Indicator Stalk all the way up to the Horn Switch.
#10 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 01 June 2021 - 05:49 PM
It does!
#11 Ethel
  • 26,074 posts
Posted 01 June 2021 - 06:59 PM
You've got:
Solid blue - supplies centre headlight contact
Blue / red is to dip beam
Blue / white is main beam & has the solid purple (permanent live) on the other side. That gives flashed full beam with not lights or dipped beam on.
There's a supply wire (that solid black?) from the solid purple up the tube of the indicator stalk for the horn push, The stalk itself is the conductor from the push switch to the horn.  If you don't fancy trying to reattach the broken wire where it can from I reckon you could do so directly to the stalk.
#12 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 02 June 2021 - 03:58 PM
Solid black is earth.
IIRC it is braided at the end and is wedged between the stalk and the switch unit when the arm is pushed into place (splined end).
Power goes to the horn from the battery/fuse box (purple) and back up to the horn push (purble/black) where it makes a circuit with the earth wire when depressed.
