Many thanks in advance for guidance.
Posted 30 May 2021 - 05:08 PM
Posted 30 May 2021 - 05:16 PM
I don't see where should it connected but the Purple-Black wire is for the horn.
Posted 30 May 2021 - 06:12 PM
Posted 30 May 2021 - 08:16 PM
yep horn all the way
Posted 31 May 2021 - 07:04 AM
Here you go, combined with black on mine:
Posted 31 May 2021 - 07:08 AM
The OP's is connected the same as yours,the unconnected wire is purple and blackHere you go, combined with black on mine:
Posted 31 May 2021 - 08:25 AM
CAREFUL!
Won't be combined with the black .. that purple wire will be separate behind the black .. black is the switch earth wire.
Posted 31 May 2021 - 11:10 AM
Ah good point, the connector is so deep it seemed joined to me. Couldn't easily pull it out either.
Posted 31 May 2021 - 06:38 PM
I'm pretty sure that wire goes up inside the Indicator Stalk all the way up to the Horn Switch.
Posted 01 June 2021 - 05:49 PM
It does!
Posted 01 June 2021 - 06:59 PM
You've got:
Solid blue - supplies centre headlight contact
Blue / red is to dip beam
Blue / white is main beam & has the solid purple (permanent live) on the other side. That gives flashed full beam with not lights or dipped beam on.
There's a supply wire (that solid black?) from the solid purple up the tube of the indicator stalk for the horn push, The stalk itself is the conductor from the push switch to the horn. If you don't fancy trying to reattach the broken wire where it can from I reckon you could do so directly to the stalk.
Posted 02 June 2021 - 03:58 PM
IIRC it is braided at the end and is wedged between the stalk and the switch unit when the arm is pushed into place (splined end).
Power goes to the horn from the battery/fuse box (purple) and back up to the horn push (purble/black) where it makes a circuit with the earth wire when depressed.
Trying To Find The Right Wire Harness Online...Started by mattaebersold , 22 Jul 2025 ![]() |
Mini Rio 93 Boot Wiring IdentificationStarted by KanKanManKan , 11 Jul 2025 ![]() |
1987 Mini Rover Fuel Gauge IssueStarted by kwfranky , 11 Jun 2025 ![]() |
