Hi everyone, hope someone can shed some light on something that's been driving me insane the last weeks. I've bought for cheap a 1275GT instrument block for my french Rover Mini British Open ('93, carb). Originally it came with a fully functioning Nippon Seikki 2-clock dash. I've been trying to install it but ran into some issues.
First i had problems getting the speedometer to work, which i ended up realizing was down to the connector on the speedo cable being different.
Now, I have a different issue - the fuel gauge is working almost randomly. Sometimes I'll turn the ignition on and get the needle to go up (fully up), only for it to go down 1 or 2 minutes after, showing an empty tank. Also, if I tilt the instrument cluster, it (sometimes) makes the needle go up or down. Do you think I have a broken gauge? I had changed the voltage stabilizer before thinking that might have been the issue, but the same problem arises with a new one.
Thanks for any clues on this!
