Mini Minor "the Doctor"
55 replies to this topic
#1 Rusty Mike
Rusty Mike
  • 83 posts
Posted 07 June 2022 - 07:38 PM
Hi Here's the start of a new project. 1960 mini minor, named it the doctor. (doc for short) I found out that the last owner/driver was a doctor, I found paperwork inside from 1984, plus I found a card inside saying Doctor on call.
she does need a bit of medical attention.
at the moment Im in the process of stripping her down so that I can start the operation.
Attached File  0013.jpg   46.93K   7 downloads
Attached File  0002.JPG   61.42K   3 downloads
more pics soon
Edited by Rusty Mike, 07 June 2022 - 07:40 PM.
#2 wingnut
wingnut
  • 463 posts
Posted 07 June 2022 - 07:50 PM
Looking forward to this one.Love the plot to
#3 sonscar
sonscar
  • 3,000 posts
Posted 08 June 2022 - 07:22 AM
Nice project,enjoy,Steve..
#4 Gaz66
Gaz66
  • 909 posts
Posted 08 June 2022 - 11:05 AM
Nurse Gladys Emmanuel springs to mind for some reason.
#5 Rusty Mike
Rusty Mike
  • 83 posts
Posted 09 June 2022 - 08:54 PM
Attached File  0019.JPG   73.6K   6 downloadsAttached File  0016.jpg   48.86K   5 downloadsAttached File  0023.JPG   75.99K   4 downloads
Thanks for the feedback
heres a couple of pics of the boot and floor
all didnt look too bad on the main floor until you give it a little poke. you can see the nice neat hole someone made for a later gearbox.
Edited by Rusty Mike, 09 June 2022 - 08:55 PM.
#6 Rusty Mike
Rusty Mike
  • 83 posts
Posted 10 June 2022 - 08:13 PM
Attached File  20220610_182933.jpg   49.89K   5 downloadsAttached File  20220610_185038.jpg   48.05K   6 downloads
Did few hours after work. just wanted to get the rear boot area a little more stable before I start the boot floor.
the rear subframe is in bad condition. not sure if the car might of had a small bump sometime.
anyway, next job put it on the turning frame.
#7 Rusty Mike
Rusty Mike
  • 83 posts
Posted 19 June 2022 - 03:32 PM
put the car on a rollover jig
Ive used this jig for a couple of capris so had to do some mods to get it to fit the mini.
Attached File  0045.jpg   35.04K   2 downloads
Attached File  0044.jpg   49.21K   2 downloads
Attached File  0047.jpg   56.25K   6 downloads
so now have to get the subframes off,
#8 Grant 111
Grant 111
  • 18 posts
Posted 20 June 2022 - 07:30 PM
Fantastic find. Look forward to seeing this progress.
#9 Rusty Mike
Rusty Mike
  • 83 posts
Posted 21 June 2022 - 10:51 AM
Thanks Grant
might be slow progress, Ive done a few capri's, so know them inside out, but dont know anything about mini's. But did have a clubman when I was 17.
#10 Rusty Mike
Rusty Mike
  • 83 posts
Posted 25 June 2022 - 07:18 PM
Attached File  20220625_141754.jpg   53.25K   2 downloads
Attached File  20220625_141808.jpg   49.26K   2 downloads
started the major operation. took both the subframes out, the front one looks to be in pretty good order, but the back one has well and truly had it. so next job is to repair the wheel tubs and weld in a new boot floor.
its funny when I read the Haynes manual, and it says its worth checking your subframe after 5 years. they didnt expect the car to last in those days, well 60 years later, I think the back one deserves a new one.
#11 Rusty Mike
Rusty Mike
  • 83 posts
Posted 08 July 2022 - 08:24 PM
Attached File  0059.jpg   33.95K   1 downloads
Started on the wheel tubs, wanted the get them cleaned and repaired before I put the boot floor in.
repaired the passenger side tub
Attached File  0055.jpg   64.69K   2 downloads
Attached File  0056.jpg   58K   2 downloads
just needs a bit of tidying up
then on to the drivers side
Edited by Rusty Mike, 08 July 2022 - 08:25 PM.
#12 Rusty Mike
Rusty Mike
  • 83 posts
Posted 07 August 2022 - 05:10 PM
so on to the boot floor, it was a bit of hassle lining everything up especially when you have no reference, due to most of the back being missing.
Attached File  0065.jpg   37.6K   3 downloads
Attached File  0066.jpg   45.62K   2 downloads
Attached File  0063.jpg   27.73K   1 downloads
just need to do some seam sealing inside the boot, I'm a bit happier now the car has some more structural integrity.
I do have some repairs to do on the rear quarters, just a few areas near the arch,
#13 Rusty Mike
Rusty Mike
  • 83 posts
Posted 01 October 2022 - 02:46 PM
done a little bit more to the mini
 Repaired both rear arches, then a skim of filler ( sand down later)
Attached File  0073.jpg   29.96K   4 downloads
Attached File  0072.jpg   29.94K   2 downloads
made a couple of repair sections for the luggage compartments will welding these in before the new floor, and ive done some repairs to the drivers sill. I suppose some would of put a new sill in, but its on a budget. especially when you've just bought the new floor. Ive put a small repair on the cross member, but this will be removed later when Ive repaired it from the underside ( only a small hole).
Attached File  0068.jpg   44.44K   2 downloads
Attached File  0069.jpg   38.61K   2 downloads.
Attached File  0070.jpg   43.74K   2 downloads
next job, the main floor
Edited by Rusty Mike, 01 October 2022 - 02:50 PM.
#14 Homersimpson
Homersimpson
  • 829 posts
Posted 01 October 2022 - 03:58 PM
attachicon.gif 0069.jpg.
Looking good, nice to see another one being saved.
Are you going to change the whole floor and is so are you going to use a MK1 floor from M Machine or are you going to fit a later floor?
#15 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 01 October 2022 - 04:39 PM
Great progress matey, looks like this one got lucky and avoided being scrapped! Glad to see it being saved.
