Hi Guys
Yeh, im going to replace the whole floor, Ive ordered one from magnum panels, its a mk1 one floor, so trying to keep it original. Its a rare survivor. from looking inside I dont think its been on the road since the late 80s .
Posted 01 October 2022 - 05:30 PM
Hi Guys
Posted 29 October 2022 - 02:18 PM
While awaiting the new floor to turn up I thought id start the a-post quarter panels. There seems to be different ones around when I've looked on the net, some seem to have a inner panel, but mine just has the outer one with 2 brackets for the door hinge welded to the A-post.
Ive taken both off, they were the original panels, but unfortunately could not be saved.
I started with the drivers side. had to do a small repair to the A-post.
082.jpg 30.57K
1 downloads
083.jpg 29.43K
1 downloads
Then made a start on the passenger side, on this side the bottom hinge support bracket has rusted away, I'm not sure if you can buy these so i may have to make one.
080.jpg 28.33K
1 downloads
085.jpg 29.76K
0 downloads
Again another small repair will be needed to the A-post.
Edited by Rusty Mike, 29 October 2022 - 02:33 PM.
Posted 05 November 2022 - 10:01 PM
So ive repaired the A-post bracket, forgot to take a pic
So made a start on the floor.
086.jpg 41.43K
0 downloads
088.jpg 63.9K
1 downloads
On further inspection Ive decided to replace the seat crossmember, it didn't look too bad till I took the floor off the underside of it, the flange along the front was badly corroded.
So once this is replaced ill carry on with the floor.
Posted 20 November 2022 - 10:13 PM
Posted 14 January 2023 - 02:13 PM
Been making slow progress, bit cold in the garage ( fan heater broke)
Got the floor welded in place, welded the seat brackets to the new cross member.
095.jpg 30.64K
1 downloads
096.jpg 44.53K
1 downloads
so now just removed the front wings and valence. need to do some repairs
092.jpg 45.26K
1 downloads
will do some more welding then get the front attached.
Posted 15 January 2023 - 10:56 AM
Nice work!
I would unscrew the damper brackets on the inner wings before starting any repairs on them. I guess you will find the red demon there also :)
Posted 21 January 2023 - 02:19 PM
Thanks for the info, Ill have a look at them.
Posted 04 February 2023 - 07:02 PM
so started the repair of the inner wings
099.jpg 37.5K
2 downloads
0100.jpg 40.54K
0 downloads
so just a few bits of corrosion where the front valence attaches, and some damage on the drivers side.
I removed the damper brackets from the inner wings, and the inner wings had no corrosion, but the brackets were full of rust And of course half of the screws snapped off, so im going to put some new screws in and weld the brackets to the inner wing. just to be doubly sure that they are secure.
Next job was to fit the bonnet, I had to make a hinge bracket for the bonnet, ive fitted the bonnet so that I can fit the wings and front valence
0103.jpg 32.29K
0 downloads
next job will be to fit the damper brackets
Edited by Rusty Mike, 04 February 2023 - 07:04 PM.
Posted 11 February 2023 - 02:57 PM
welded the damper brackets.
Then started to look at fitting the wings, and front valence.
0106.jpg 28.86K
0 downloads
0107.jpg 31.87K
2 downloads
but the wings aren't the best
0112.jpg 32.08K
2 downloads
had to butcher it, but doesn't fit, so going to buy a heritage panel and try again.
0111.jpg 29.76K
2 downloads
so will wait and see how the heritage panel fits on the passenger side, if its good I might buy another for the drivers side.
Posted 24 March 2023 - 10:04 PM
so I've cleaned and painted the front subframe. The suspension cones are still in place, I'm just waiting for a compression tool, I'll take them out and check them once I have the tool.
0120.jpg 53.21K
0 downloads
Then painted the inner wings
0124.jpg 33.82K
0 downloads
0125.jpg 30.01K
0 downloads
After that I removed the frame from the engine bay, then it took me 3 hours to remove the brake and clutch reservoirs, the split pins didn't want to come out , but got there eventually. now just need to remove the other bits so that I can clean and paint the engine bay.
Edited by Rusty Mike, 01 April 2023 - 08:13 PM.
Posted 01 April 2023 - 05:59 PM
so I've receive the compression tool, so now I took off the front suspension cones, cleaned and re-greased the the top shafts and fitted them back on to the front subframe. Then I put the subframe back on the front of the car, I was a little worried that it might not fit after replacing the front end, But got away with it and it fitted fine.
0127.jpg 51.05K
1 downloads
Then I realised that I've not fitted the steering rack, so according to the manual I have to drop the front subframe to fit the steering rack. ( typical) I should start reading the Manual.
