Gears ..for A Dam2886 Box
Best Answer Spider , 07 December 2022 - 04:12 AM
It does sound to me like there's an issue with the alignment of the shifter rods and / or the shifter itself to the gearbox, also, when you next have the coupling off, give the shifter stick a good slow movement throughout it's full range of movement to feel for anything that's tight or notchy.
So, adjusted everything did a cross check and now I get 2/3/4/R very smoothly but no first gear. also, sort of a hollow noise coming from the clutch area, removed wok and checked and looked okay though - no first gear??
Also at first no gears, adjusted big nut out more, everything except 1st - tomorrow adjust nut all the way just curious
Seems you're getting somewhere, albeit, slowly.
When the car is stationary, engine off, can you select 1st gear then ? Check it's in gear if you think you can get it in, by pushing the car.
Go to the full post
84 replies to this topic
#16 Spider
  • 15,873 posts
Posted 25 October 2022 - 07:57 PM
 ,,,,,and interestingly enough the video I sent works wonders for me,
Oh I've no doubt they 'work' and clearly show getting the job done, but it's how the job gets done in all the clips I've seen. Maybe I'm pedantic ? I just don't like some of the workshop practices I see. Things like bashing bearings in and out, prying gasketed parts apart with levers etc. Yes, they get the job done, but in my view and from all the things I've seen over the past 35+ years, these poor practices are what lead to short life, oil leaks and worse.
#17 postve
postve
  • 588 posts
Posted 28 October 2022 - 12:43 AM
Spider, I would agree 100% as watching it, although it does work for me, he is kinda rough at times and repeated some steps do to incorrect sequencing. It works cause I can learn from his mistakes indeed
Just waiting for my mini spares puller as want to show you the gear box and praying not cracked.. gears,gaskets, arrives today
Edited by postve, 28 October 2022 - 12:44 AM.
#18 postve
postve
  • 588 posts
Posted 04 November 2022 - 11:39 AM
Ok so decided to flip the engine on its side and remove gears, changed all gaskets, pasted it up and now going back in
#19 postve
postve
  • 588 posts
Posted 16 November 2022 - 11:30 PM
All in and nowwwww.. clutch will not disengage - lol - did everything by the book and down to replacing the release bearing plunger etc and note the clutch is basically brand new with only 600k on it did the following;
- bleed clutch
- Changed slave - it was brand new anyways but had old one
- changed clutch arm - brand new but had old one
- usual gap - 0.25mm - release bearing adjusted big nut accordingly
- changed cleavis pins (why not)
- removed starter to see if by keeping clutch pedal down could I freely turn clutch - nope
- I did notice the diaphragm bolts on my MED ST3 lightened flywheel were so loose I could remove my hand - that was me not torquing to the correct 18psi - this I believe was the rattling I started hearing when car was idling with clutch NOT depressed all the way down
Ok out of options and will see what release bearing does and will be damned if that expensive clutch is gone
#20 postve
postve
  • 588 posts
Posted 16 November 2022 - 11:32 PM
Pic of primary gear through the starter
Edited by postve, 16 November 2022 - 11:32 PM.
#21 postve
postve
  • 588 posts
Posted 16 November 2022 - 11:36 PM
More pics
#22 GraemeC
GraemeC
  • 7,475 posts
Posted 17 November 2022 - 09:17 AM
So, with someone else pushing the pedal, can you see the backplate move away from the flywheel?
#23 postve
postve
  • 588 posts
Posted 17 November 2022 - 09:25 AM
It just stays in this position so no
Edited by postve, 17 November 2022 - 09:29 AM.
#24 GraemeC
GraemeC
  • 7,475 posts
Posted 17 November 2022 - 09:33 AM
OK - that narrows things down then.  You won't turn anything with your screwdriver if the backplate isn't moving and releasing the driven plate.
When you had the flywheel off, did you disassemble the clutch components?  Do you have any photos of the flywheel when installed?
#25 postve
postve
  • 588 posts
Posted 17 November 2022 - 09:59 AM
It was a pre balanced lightened flywheel from MED so nothing to take apart - let me get some pics
#26 postve
postve
  • 588 posts
Posted 17 November 2022 - 10:03 AM
Here’s a pic
#27 imack
imack
  • 2,382 posts
Posted 17 November 2022 - 10:30 AM
Photos not very clear but something doesn't look right with the release bearing thrust plate on the diaphragm. Is it fitted the right way round? The retaining clip is certainly incorrectly
#28 postve
postve
  • 588 posts
Posted 17 November 2022 - 10:50 AM
I was thinking about it but I even marked it when I removed to make sure I did not make that error. Again was one of the first things I checked as should be convex
Correct me if I am wrong
#29 postve
postve
  • 588 posts
Posted 17 November 2022 - 11:08 AM
In addition the oil seal is new, zero oil in clutch housing and generally it all looked good,
#30 GraemeC
GraemeC
  • 7,475 posts
Posted 17 November 2022 - 12:05 PM
It does look odd, but it could just be the photo.  The clip is definitely wrong but that shouldn't cause the issue you're having.
So next thing to try.  Again with your assistant, get them to push the pedal down and check that the pushrod extends out of the slave cylinder by 1/2".
At this stage, until you have it all working, I would unwind the big throw out nuts so they are well clear of the wok.
