City Rebuild/straightening
#181
Posted 04 August 2008 - 06:37 PM
#182
Posted 04 August 2008 - 06:46 PM
#183
Posted 04 August 2008 - 07:20 PM
Dave
#184
Posted 04 August 2008 - 08:40 PM
Edited by Tom Booth, 04 August 2008 - 08:41 PM.
#185
Posted 07 August 2008 - 04:45 PM
#186
Posted 07 November 2008 - 05:50 PM
-Turbo lumps off to Benross tomorrow to be rebuilt at 1293 spec
Brought a few goodies for the turbo engine, other then that not alots happened. Just been pootling round to uni and back etc. Will post when actual event's occur....
#188
Posted 15 November 2008 - 12:36 AM
#189
Posted 07 December 2008 - 12:55 AM
Block - 1293cc using Omega 10cc dished +20 pistons
Crank regrind, new shells and thrusts
Kent 276 cam, new oil pump and followers
Duplex timing gear
Oil Gallery plugs removed and fitted with Allen headed 3/8th stubs an new core plugs
Painted +30bhp BMC Green!
Head - Chambers enlarged to 28cc (Comp ratio around 8:5:1, good for around 20psi)
New unleaded hardened valves with new seats, guides and oils stem seals
Mild porting too. Double Valve springs 180lb's
Going to be using the standard box for now, aswell as drop gears. Should see about 130bhp@10psi, but with massive torque figures due to the cam and turbo which is what I want mainly. When funds have recovered from the build, I'm going to start to build a SC box, with Minispares Evolution drop gears using the timkin idler gear, so the I should be able to wind the boost up and go to around 16-17 psi, which should see 160-170 bhp
The short motor should hopefully be back next sunday providin the cam shows up before wednesday. Been spending copious amounts of money on bit and bobs recently thou, fuel lines, injection rated fuel hose, boost controller (Under bonnet
I need to ring Maniflow on monday and get my exhaust ordered so thats ready for the transplant. Aswell as order my minispares 4 pin diff, to get that can be fitted while the gearbox is easier to handle.
That's all for now folks! I'll update with pictures when I have something to update with
#190
Posted 07 December 2008 - 01:35 AM
#191
Posted 08 December 2008 - 10:51 AM
Just got off the phone to maniflow, Downpipe and center exit 2" single box on it's way
#192
Posted 09 December 2008 - 11:45 PM
Biiig minispares box full of a super 2 core rad, thermostat, new hoses, water pump, 70amp alternator, fuel pressure regulator, 3/8" copper fuel line, 10mm rubber fuel pipe, few fittings, a few gaskets.
Lads at maniflow got my exhaust to me today which is also awesome.
Engines back from the machine shop, cranks being collected tomorrow, then it should all be built soon providing this cam turns up after a bit of confusion with the postie!
It's all looking thumbs up for the christmas install!
#193
#194
Posted 12 December 2008 - 01:22 PM
#195
Posted 12 December 2008 - 07:59 PM
