im bidding on some shocks on ebay atm too! to make the thing grip, as theres no point in having lots of power if i cant use it!
might, but not sure yet get some revos in 5.5" but could really do with photoshoping them on first
Winston 1275- 1340cc
TimS
, Jan 19 2005 12:34 AM
53 replies to this topic
#46
Posted 05 April 2005 - 03:07 PM
#47
Posted 05 April 2005 - 07:36 PM
dont think revo's would suit the car mate
their nice rims and all, but i dont think they'd look quite right
try some superlights with yoko rubber is what i'd go 4
ur decision tho
ur decision tho
#48
Posted 05 April 2005 - 07:46 PM
its the width though, i want something around 5.5"
#49
Posted 05 April 2005 - 07:47 PM
im going for 5.5, or if not 6, but definately yokohama rubber, for reasons you know, think u should do the same
#50
Posted 05 April 2005 - 08:02 PM
i recon same wheels
i get some photoshops done if there is any12 out there that can help, it would be welcomed
#51
Posted 03 May 2005 - 08:57 PM
ok finally after taking a few days off uni i came back home to finish my engine build and to change everything over!
It took 5 hard days of work but i finall got the new pads in, caliper bolts changed, brakes bled, rose jointed bottom arms on and set up, the tie bar bushes changed.
The the finished building the engine and painting the bay.
Then came to starting it which was a disaster... the catr started first time and disdnt even take half a crank of the new battery, but one it was running there was smoke, not just a little smoke buit alot it managed to fill my front garden. straight away i had the sinking feeling that it was the oil ring that id changed from snapping the original. after taking out the plugs there was oil over the plug in this cylinder and later taking off the head showed this. So hopfully in 2-3 wereks time i shall b sterippuing the engine again and changin all over the rings, re-lubing the cam with cam lube(i only used oil b4 and the engine had run for less than 1 minute) and while its apart ive decided to change the cluch friction flate for a turbo one and change the head gasket from an AF460 to a BK450... its so frustrating but as its my first engine build im leanring the hard way but at the same time just keep added more and more new bits :grin:
#52
Posted 03 May 2005 - 08:58 PM
one with james wynn (madmax) in
#53
Posted 03 May 2005 - 11:51 PM
famous :cool:
#54
Posted 04 May 2005 - 03:47 PM
Thats so cruel mate, but hey, its looking good. At least there is a guide for engine builds when I come to do mine :grin:
