Clubby Estate - The Rot Box
138 replies to this topic
#46 Jackman
Jackman
  • 4,053 posts
Posted 21 October 2008 - 02:31 PM
Thanks Ed.
Hows uni going?
#47 knightal7
knightal7
  • 26 posts
Posted 21 October 2008 - 03:01 PM
Nice job good to see another K head project on here other than my own i will be keeping an eye on your progress
#48 tedmcedd
tedmcedd
  • 2,751 posts
Posted 22 October 2008 - 11:46 AM
Yeah its going well sir! thanks! im up home this weekend for a club meet! cant wait to drive the bean again... he is currently living in my grans barn....
#49 Jackman
Jackman
  • 4,053 posts
Posted 29 November 2008 - 06:31 PM
Update
Well im well stuck now. The inner wings will not line up at all, the gaps are all wrong, the holes dont line up and its either too high or too low :P
Drivers side on
Top a panel gap
Thats not right at all.
Holes well out, that pushes the inner wing too high at the front, puting it back down makes the inner wing the right hight at the front.
Front Panel lined up.
Front kinda on.
The last picture makes me feel good about the project but dont understand the gaps.
#50 Junior Mini
Junior Mini
  • 313 posts
Posted 29 November 2008 - 06:57 PM
I had the same problem when i fitted my inner wings.The shock mount holes never seem to line up properly, but you can get all the bolts in. My lower holes still seem well high. As for the door shuts, don't worry, if you haven't taken the doors off then the hinges are proberly still shimmed to the old 'A' panel. The gaps will shim up well, mine did (Eventually :P )
Edited by Junior Mini, 29 November 2008 - 06:58 PM.
#51 Bec
Bec
  • 5,900 posts
Posted 29 November 2008 - 07:07 PM
Awww Chris that looks like a 'mare, hope you can get it lined up and fitted, just don't unleashed the BFH on it :P
The last pic though, you can really see things to come :P
#52 Jackman
Jackman
  • 4,053 posts
Posted 29 November 2008 - 08:35 PM
Thats what im woried about, the top hinge has 2 shims on already yet wont open with the new a-panel, but if i add another shim the door wont close as i need to remove a shim to make it close. Im really stuck with it.
The shock mount holes are about 1cm out, pushing it around to make them fit makes the front sit 1cm to high to fit the front subframe mounts.
Cant win with it, the passenger side is exactly the same.
Thanks Bec, i wasnt going to put them on but i did just to try make me feel better.
#53 Jackman
Jackman
  • 4,053 posts
Posted 30 November 2008 - 04:00 PM
Well its looking up.
After a chat with Sprox last night and my friend Paul today ive got the holes lining up and the gaps right.
Jacked the car up off the ground and then hit the subframe with a hammer after putting a jack towards the crease, the holes are now in the right spots and the crease near enough gone :thumbsup:
WOO! Put the entire front end back together, all the lines look good and straight. Think its nearly time for the welder to come out.
#54 666junky
666junky
  • 1,225 posts
Posted 01 December 2008 - 12:09 PM
Glad you got it sorted :P
cant wait to see all the front on teehee, i vote you sneak home and get welding >_<
#55 Bean
Bean
  • 8,054 posts
  • Name: Jean
Posted 01 December 2008 - 12:35 PM
Kris had huge problems with the inner wings on his Pick-Up!
Turns out that they were made over 10mm too short!
It's really not what you expect from genuine panels :P
Glad it's lined up though - Well done! >_<
#56 tedmcedd
tedmcedd
  • 2,751 posts
Posted 01 December 2008 - 12:42 PM
ahhh the old 'hit it with a hammer' trick... lol!!
glad its all coming together!! get the welder out!!
#57 Jackman
Jackman
  • 4,053 posts
Posted 01 December 2008 - 12:44 PM
Thanks peeps.
The hammer maybe an understatment... it was a 18pound sledge hammer against the subby to bend it right. Its all good now tho.
Once its welded up, it goes on the spit then the floor comes out.
#58 Jackman
Jackman
  • 4,053 posts
Posted 20 December 2008 - 03:29 PM
Small update.
Did a bit of welding after fixing the welder again (got bad feeling about the welder) now the steady mount on the crossmember has been welded back on and the crack fixed. Then ground it all back so it looked neater ;)
Tomorrow i may remove the inner wings and start making holes for the plug welds.
#59 benb12
benb12
  • 1,483 posts
Posted 20 December 2008 - 03:57 PM
Nice project, it's looking good. ;)
#60 racer36
racer36
  • 327 posts
Posted 20 December 2008 - 04:42 PM
thats amazing work mate ! keep it up im defo gunna follow this topic lol
well done ;) :teehee:
